Hi, I'm using a 4051 to get multiple 10k pots into one analog in. It has started to work well, but I'm having an issue. One pot specifically, when I turn it all the way up seems to crash the arduino. I get the following error message:
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
at gnu.io.RXTXPort.nativeavailable(Native Method)
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
at processing.app.Serial.serialEvent(Serial.java:215)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
If I leave this pot all the way up- the arduino is undiscoverable. The system doesn't recognize it, the COM 4 port is missing, etc etc. But when I use the other two pots- I can turn them all the way up and it doesn't matter.
I'm not sure how much I can get into the details without you guys helping with my muxing project. I'm new here, new to arduino and all of that, but mildly tech savy. I'm assuming there is something shorting out somewhere. Any ideas on where to start looking? I'm using the 5v power pin on a Duemilanove.
Any help is appreciated.
