Muxshield - how connect?
Hello everyone,
I am a newbie in Arduino and in all about this and I would like to use Muxshield II with Arduino MEGA.
if I connect this parts as on the image - it's all? I can connect sensors on this pins and it will be to function?
Thank you very much :slight_smile:
Yes.
If you write the code correctly, yes.
Ok, so If I use this schema where R is resistor and S are reed sensors - it´s right yes?
I connect pin on the 3th row on pin 14 and 15.
And I use a program (from examples for muxshield):
//This example shows how to use the Mux Shield for digital inputs
#include <MuxShield.h>
//Initialize the Mux Shield
MuxShield muxShield;
    muxShield.setMode(3,DIGITAL_IN_PULLUP);
//Array to store digital values
int IO3DigitalVals[16];
  for (int i=0; i<16; i++)
    IO3DigitalVals[i] = muxShield.digitalReadMS(3,i);
  //Print IO 1 values for inspection
  Serial.print("IO3 digital values: ");
    Serial.print(IO1DigitalVals[i]);
    Serial.print('\t');
I will get a values from 0 to 15 - 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 ? This is good result?
Because I connect app. 30 reed switches and if I try to put a magnet on one reed switch.. a many from this pins return 1 and I don´t know why. So this is a reason why I start ask if I have good connection of muxshield - because when I try to turn on one reed switch, always are another changed.
How far apart are the reed switches? Is the magnet triggering more than one of them?
No it is not possible - reed switches are very far approximatly 30 mm and magnet - which I try to reed switch is very small. A lot of pins are changed from 0 to 1 - but connection is Ok? This is first thing what I need to know :frowning:
You have the mode set as DIGITAL_INPUT_PULLUP. Because of that (and that's the way you do want to do it) I believe you want to have the resistor in your diagram connected to GND instead of 5V.
Setting the pull-up, which is like connecting a 20K resistor between 5V and the input pin, causes the pin to read as high when the reed switch is open. When the reed switch closes and completes a circuit to GND it will then read low. You can read up on https://www.arduino.cc/en/Tutorial/DigitalPins to understand what's going on here.
I've never touched the Muxshield so this is mostly an educated guess.
When you use DIGITAL_IN_PULLUP you should connect each reed switch between its input pin and GROUND. Don't use a resistor.
I am sorry for my late response but I had a lot of work. But I think that I wrote a wrong schema . It have to be connected like this:
It is true?
No, the switch goes simply between pin and ground. Nothing else needed.
Ok thanks much :slight_smile:
