Hi everyone,
is it possible to efficiently control a BLDC motor with an MX1508 + Ard. Nano like it is with an L298 (no decoder)?
I tried the same code and pin hookup as I did with the Nano+L298, but I could not get the same strong and stable code-controllable rotation. IE the motor would just throb if not "jump-spun" by hand. So in other words, not working!
I am using using 5V power and a ⌀28mm OD, hollow shaft, 12 coil/3 wire outrunner brushless motor.
I'm working on a hobby project and size is a bit of an issue, so I would much rather use an MX1508 if at all possible.
Even a simple "yes" or "no" answer would greatly help, but feel free to suggest code and layout (hookups), thanks!
