sory about the coding with the comment just got mad at it at one point.. i think I've figured it out though, ive got it compile but dont know if it will work. the promble was that i had a chuck of coding outside a set of brackets so i tried to put it in. It's the last bit of coding at the end.
#include <SoftwareSerial.h> //Software Serial library
#define DEBUG 1
#define DEBUG true
#include <Wire.h> // for some strange reasons, Wire.h must be included here
#include "DS1307new.h" // extension to new DS1307 Arduino library that includes weekday alarms
SoftwareSerial espSerial(2, 3); //Pin 2 and 3 act as RX and TX. Connect them to TX and RX of ESP8266
String mySSID = "TelstraDB54ED"; // WiFi SSID
String myPWD = "axgv4k4vza"; // WiFi Password
String myAPI = "203324YPH9HWHVWM"; // API Key
String myHOST = "api.thingspeak.com";
String myPORT = "80";
String myFIELD = "field1";
const int AirValue = 520; //you need to replace this value with Value_1
const int WaterValue = 260; //you need to replace this value with Value_2
int intervals = (AirValue - WaterValue)/3;
int soilMoistureValue1 = 0; //A0 HIGH BEDS
int soilMoistureValue2 = 0; //A1 LOW BEDS
int waterSensor1 = 6;
int waterSensor2 = 7;
int SVLowBed1 = 8;
int SVLowBed2 = 9;
int SVHighBed1 = 3;
int SVHighBed2 = 4;
int Q = 0;
int UVsensor = A2;
pinMode(SVLowBed1, OUTPUT);
pinMode(SVLowBed2, OUTPUT);
pinMode(SVHighBed1, OUTPUT);
pinMode(SVHighBed2, OUTPUT);
digitalWrite(waterSensor1, HIGH);
digitalWrite(waterSensor2, HIGH);
espSerial.begin(115200);
espData("AT+RST", 1000, DEBUG); //Reset the ESP8266 module
espData("AT+CWMODE=1", 1000, DEBUG); //Set the ESP mode as station mode
espData("AT+CWJAP=""+ mySSID +"",""+ myPWD +""", 1000, DEBUG); //Connect to WiFi network
#ifdef DEBUG
// init serial communication
while(!Serial) {} // for Arduino Leonardo
#endif
// uncomment line below if you explicitly want to set the time
//RTC.setRAM(timeIsSetAddress, (uint8_t *)&aspectIsNotSetToken, sizeof(uint8_t));
// check if flagged that time was already set in RTC
if (RTC.isTimeSet()) {
// OK RTCandA was properly set, so let get the time
RTC.getTime();
// only do this once to set the RTC
// this routine writes the token to the RTC NV-RAM memory for future reference
RTC.setDateTimeRTC();
//examples how to set alarms [alarms are defined at at 5 minute resolution]
RTC.clearAlarmNvramMemory(); // clears the DS1307 internal NVRAM to hold the alarms
RTC.listNvramMemory(); // print out the NVRAM memory values
// set alarm Mondays at 5:25,
// first parameter is day of the week (sunday = 0, monday = 1, ..., saturday = 6)
// second parameter is the hour in 24h style
// last parameter is the minutes in 5 minute resolution, i.e. 0, 5, 10, 15, 20, 25, 30, 35, 40, 45, 50, 55
RTC.setAlarm( 0, 6, 0);
RTC.setAlarm( 1, 6, 05); // set alarm Tuesdays at 16:05
RTC.setAlarm( 2, 6, 10); // aet alarm Wednesday at 12:10
RTC.setAlarm( 3, 6, 15); // set alarm Thursdays at 11:25
RTC.setAlarm( 4, 6, 20);
RTC.setAlarm ( 5, 6, 25); // set alarm Saturdays at 20:00
/* can not be all 6 o'clock because arduino is a fag. has to
be five minutes difference. does everyday exspect Sunday */
#ifdef DEBUG
Serial.println("DS1307 time and alarm memory module");
Serial.println("Format is "hh:mm:ss dd-mm-yyyy DDD"");
uint8_t CEST = RTC.isCETSummerTime();
Serial.print("isCETSummerTime=");
Serial.println(CEST, DEC);
#endif
delay(100);
- main loop of the sketch
/* Here, I'm using the function random(range) to send a random value to the
ThingSpeak API. You can change this value to any sensor data
so that the API will show the sensor data
// VAL = analogRead(Sensor1); // Send a random number between 1 and 1000
// VAL = analogRead(Sensor2);
UVsensor = analogRead(A2);
// Serial.println(Sensor1);
//Serial.println(Sensor2);
Serial.println(UVsensor);
String sendData = "GET /update?api_key="+ myAPI +"&"+ myFIELD +"="+String(UVsensor);
espData("AT+CIPMUX=1", 1000, DEBUG); //Allow multiple connections
espData("AT+CIPSTART=0,"TCP",""+ myHOST +"","+ myPORT, 1000, DEBUG);
espData("AT+CIPSEND=0," +String(sendData.length()+4),1000,DEBUG);
espSerial.find(">");
espSerial.println(sendData);
Serial.print("Value to be sent: ");
espData("AT+CIPCLOSE=0",1000,DEBUG);
String espData(String command, const int timeout, boolean debug)
Serial.print("AT Command ==> ");
Serial.print(command);
Serial.println(" ");
String response = "";
espSerial.println(command);
long int time = millis();
while ( (time + timeout) > millis())
while (espSerial.available())
char c = espSerial.read();
response += c;
if (debug)
Serial.print(response);
return response;
RTC.getTime(); // get current time from the DS1307 RTC chip
RTC.printTime(); // print it to serial
// check if alarms need to be triggered
if (RTC.isAlarmTime())
while (Q<10) {
#ifdef DEBUG
Serial.println("Alarm time has passed!");
Serial.println("Monitor 1: ");
soilMoistureValue1 = analogRead(A0); //put Sensor insert into soil
Serial.println(soilMoistureValue1);
delay(100);
if(soilMoistureValue1 > WaterValue && soilMoistureValue1 < (WaterValue + intervals))
Serial.println("Very Wet");
else if(soilMoistureValue1 > (WaterValue + intervals) && soilMoistureValue1 < (AirValue - intervals))
Serial.println("Wet");
else if(soilMoistureValue1 < AirValue && soilMoistureValue1 > (AirValue - intervals))
Serial.println("Dry");
digitalWrite(SVHighBed1, HIGH);
digitalWrite(SVHighBed2, HIGH);
delay(600000);
digitalWrite(SVHighBed1, LOW);
digitalWrite(SVHighBed2, LOW);
delay(1000); // wait 1 seconds
Serial.println("Monitor 2: ");
soilMoistureValue2 = analogRead(A1); //put Sensor insert into soil
Serial.println(soilMoistureValue2);
delay(100);
if(soilMoistureValue2 > WaterValue && soilMoistureValue2 < (WaterValue + intervals))
else if(soilMoistureValue2 > (WaterValue + intervals) && soilMoistureValue2 < (AirValue - intervals))
else if(soilMoistureValue2 < AirValue && soilMoistureValue2 > (AirValue - intervals))
Serial.println("turning on HighBeds");
delay(600000);
Serial.println("turning off HighBeds");
delay(100);
Serial.println("cycle has been run");
#endif
Q++;
