My 4 x 4 timer wont jump to another function to make my sensor PIR enable
I want my keypad when the timer is counting until 0 second, it will jump to another function but it wont happen
#include <Keypad.h>
//#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);  //0x27 is the i2c address, while 16 = columns, and 2 = rows.
const uint32_t alarm = 300000;
#include<stdio.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int relay = 13;
int buzzer = 12;
int PIR = 10;
const int motionpin = A0;
int motionsensvalue=0;
int counter = 0;
int attempts = 0;
int max_attempts = 3;
String mymints;
int minutes = 0;
String mysecs;
int seconds = 0;
long int total_seconds = 0;
int secflag = 0;
int timer_started_flag = 0;
// Tracks the time since last event fired
unsigned long previousMillis=0;
unsigned long int previoussecs = 0;
unsigned long int currentsecs = 0;
 unsigned long currentMillis = 0;
  int interval= 1 ; // updated every 1 second
int tsecs = 0;
void setup(){
  lcd.begin();                 //Init the LCD
  lcd.backlight();            //Activate backlight
  pinMode(relay, OUTPUT);
  pinMode(PIR, INPUT);
  digitalWrite(relay, LOW);
  digitalWrite(buzzer, LOW);
  Serial.println("enter password");
    lcd.print("Countdown Timer");
    delay(2000);
    lcd.clear();
     lcd.print("Enter Minutes:");
 keypadfunction();
void keypadfunction()
 char key = keypad.getKey();
  if (key){
    Serial.println(key);
    counter = counter + 1;
    lcd.setCursor(counter, 1);
    lcd.print(key);
  if (key == '1')
    mymints = mymints + 1;
    if (key == '2')
    mymints = mymints + 2;
  if (key == '3')
    mymints = mymints + 3;
   if (key == '4')
    mymints = mymints + 4;
  if (key == '5')
    mymints = mymints + 5;
   if (key == '6')
    mymints = mymints + 6;
   if (key == '7')
    mymints = mymints + 7;
   if (key == '8')
    mymints = mymints + 8;
  if (key == '9')
    mymints = mymints + 9;
                 if (key == '0')
    mymints = mymints + 0;
                    if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    lcd.clear();
    lcd.setCursor(0,0);
        if (key == '*')
lcd.clear();
minutes = mymints.toInt();
Serial.println(minutes);
lcd.clear();
lcd.print("Minutes: ");
lcd.setCursor(0,1);
lcd.print(minutes);
mymints = ""; // empty the string
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter Seconds:");
counter = 0;
secflag = 1;
while(secflag == 1)
forSeconds();
void forSeconds()
  if (key){
    lcd.print(key);
  if (key == '1')
   mysecs = mysecs + 1;
    if (key == '2')
   mysecs = mysecs + 2;
  if (key == '3')
    mysecs = mysecs + 3;
   if (key == '4')
    mysecs = mysecs + 4;
  if (key == '5')
    mysecs = mysecs + 5;
   if (key == '6')
    mysecs = mysecs + 6;
   if (key == '7')
    mysecs = mysecs + 7;
   if (key == '8')
    mysecs = mysecs + 8;
  if (key == '9')
    mysecs = mysecs + 9;
                 if (key == '0')
    mysecs = mysecs + 0;
                   if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    lcd.clear();
    lcd.setCursor(0,0);
        if (key == '*')
lcd.clear();
seconds = mysecs.toInt();
Serial.println(seconds);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Seconds: ");
lcd.setCursor(0,1);
lcd.print(seconds);
mysecs = ""; // empty the string
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Mins      Secs");
lcd.setCursor(1,1);
lcd.print(minutes);
lcd.setCursor(10,1);
lcd.print(seconds);
total_seconds = (minutes * 60) + seconds ;
counter = 0;
secflag = 0;
timer_started_flag = 1;
lcd.clear();
lcd.print("T Seconds:");
lcd.setCursor(11,0);
lcd.print( total_seconds );
delay(3000);
while( timer_started_flag == 1)
  if (key){
   if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    total_seconds = 0;
    lcd.clear();
    lcd.setCursor(0,0);
         //  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  if( total_seconds > 0)
  lcd.print("load ON ");
    if( total_seconds <= 0)
    total_seconds = 0;
    digitalWrite(relay, HIGH);
    tone(buzzer,100,1000);
    delay(10000);
    pilihan();
    lcd.print("load OFF");
     currentMillis = millis();
   currentsecs = currentMillis / 1000;
    if ((unsigned long)(currentsecs - previoussecs) >= interval) {
      total_seconds = total_seconds - 1;
      lcd.clear();
      previoussecs = currentsecs;
void pilihan()
  char choice = keypad.getKey();
  switch (choice){
    case 'B' :
    lcd.clear();
    lcd.print("Not Set Timer");
    not_set_timer();
void not_set_timer(){
  Serial.println("Not Set Timer");
  while(motionsensvalue=analogRead(motionpin))// reads analog data from motion sensor
    if (motionsensvalue>=200){
      if (choice == 'C'){
      lcd.clear();
      lcd.setCursor(0,1);
      lcd.print("B. Not Set Timer");
      break;}
      else{
      lcd.clear();
      digitalWrite(relay,LOW);
      noTone(buzzer);
      delay(5000);
    else {
      lcd.clear();
      lcd.print("Press C to Stop");
      digitalWrite(relay,HIGH); //turns on alarm buzzer
      tone(buzzer,100,5);
      delay(200);
      noTone(buzzer);
      keypadfunction();
    if (choice == 'C'){
      lcd.clear();
      lcd.setCursor(0,1);
When i click my pad to setting time for timer using 4 x 4 pad, it wont happen. I dont know why, please help
#include <Keypad.h>
#include <Wire.h>
#include<stdio.h>
//Variabel Keypad
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
//Variabel PIR
const int motionpin=A0;
int relay = 11;
const int ledpin=13;
const int buzzpin=12; // ledpin,motionpin and buzpin are not changed throughout the process
//variabel timer
int counter = 0;
int attempts = 0;
String mymints;
int minutes = 0;
String mychoice;
int choice = 0;
String mysecs;
int seconds = 0;
int secflag = 0;
// Tracks the time since last event filedpin
int tsecs = 0;
pinMode(ledpin, OUTPUT);
pinMode(motionpin,INPUT);
pinMode(buzzpin,OUTPUT);
delay(2000);
lcd.clear();
Serial.println("idle_state");
  lcd.print("A. Set Timer");
  lcd.setCursor(0,1);
  lcd.print("B. Not Timer Set");
//Main Code
  switch (choice){
    case 'A' :
    keypadfunction();
    case 'B' :
    lcd.clear();
    not_set_timer();
    case 'C' :
    lcd.clear();
    lcd.print("Stop");
    digitalWrite(ledpin,LOW);
    default:
void set_timer(){
  choice = 0;
  lcd.clear();
  lcd.print("Set Timer");
  keypadfunction();
      choice = 0;
      if (choice == 'C'){
      lcd.clear();
      lcd.setCursor(0,1);
      break;}
      else{
      lcd.clear();
      tone(ledpin,LOW);
      noTone(buzzpin);
      delay(5000);
    else {
      choice = 0;
      lcd.clear();
      tone(buzzpin,100,5);
      delay(200);
      noTone(buzzpin);
    if (choice == 'C'){
      choice = 0;
      lcd.clear();
      lcd.setCursor(0,1);
  lcd.clear();
  lcd.print("Enter Minute");
  if (key){
    lcd.print(key);
  if (key == '1')
    if (key == '2')
  if (key == '3')
   if (key == '4')
  if (key == '5')
   if (key == '6')
   if (key == '7')
   if (key == '8')
  if (key == '9')
                 if (key == '0')
                    if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    lcd.clear();
    lcd.setCursor(0,0);
        if (key == '*')
lcd.clear();
lcd.clear();
lcd.setCursor(0,1);
lcd.print(minutes);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
counter = 0;
secflag = 1;
while(secflag == 1)
forSeconds();
void forSeconds()
  if (key){
    lcd.print(key);
  if (key == '1')
    if (key == '2')
  if (key == '3')
   if (key == '4')
  if (key == '5')
   if (key == '6')
   if (key == '7')
   if (key == '8')
  if (key == '9')
                 if (key == '0')
                   if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    lcd.clear();
    lcd.setCursor(0,0);
        if (key == '*')
lcd.clear();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(seconds);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(1,1);
lcd.print(minutes);
lcd.print(seconds);
counter = 0;
secflag = 0;
lcd.clear();
delay(3000);
  if (key){
   if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    total_seconds = 0;
    lcd.clear();
    lcd.setCursor(0,0);
         //  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
    digitalWrite(ledpin, LOW);
    total_seconds = 0;
    digitalWrite(ledpin, HIGH);
      lcd.clear();
Cross posted >> My 4 x 4 timer wont jump to another function to make my sensor PIR enable
I have merged your posts due to them having too much overlap on the same subject matter @rdaffa59.
In the future, please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple threads on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Thanks in advance for your cooperation.
is this a 3rd posting?
https://forum.arduino.cc/t/keypad-4-x-4-wont-work/1067509/2
I'm trying to use an Arduino UNO to read which button I push on a 4x4 matrix keypad, then output it on an LCD screen. However, I can't get the Arduino to read 4 x 4 pad when i pressed "B", it should go to another function and the keypad is work, but it doesn't.
Please help :frowning:
#include <Keypad.h>
#include <Wire.h>
#include<stdio.h>
//Variabel Keypad
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
//Variabel PIR
int relay = 11;
//variabel timer
int counter = 0;
int attempts = 0;
String mymints;
int minutes = 0;
String mychoice;
int choice = 0;
String mysecs;
int seconds = 0;
int secflag = 0;
int tsecs = 0;
delay(2000);
lcd.clear();
  lcd.setCursor(0,1);
//Main Code
  switch (choice){
    case 'A' :
    keypadfunction();
    case 'B' :
    lcd.clear();
    not_set_timer();
    case 'C' :
    lcd.clear();
    lcd.print("Stop");
    default:
void set_timer(){
  choice = 0;
  lcd.clear();
      choice = 0;
      if (choice == 'C'){
      lcd.clear();
      lcd.setCursor(0,1);
      break;}
      else{
      lcd.clear();
      tone(ledpin,LOW);
      noTone(buzzpin);
      delay(5000);
    else {
      choice = 0;
      lcd.clear();
      delay(200);
      noTone(buzzpin);
    if (choice == 'C'){
      choice = 0;
      lcd.clear();
      lcd.setCursor(0,1);
  lcd.clear();
  if (key){
    lcd.print(key);
  if (key == '1')
    if (key == '2')
  if (key == '3')
   if (key == '4')
  if (key == '5')
   if (key == '6')
   if (key == '7')
   if (key == '8')
  if (key == '9')
                 if (key == '0')
                    if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    lcd.clear();
    lcd.setCursor(0,0);
        if (key == '*')
lcd.clear();
lcd.clear();
lcd.setCursor(0,1);
lcd.print(minutes);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
counter = 0;
secflag = 1;
while(secflag == 1)
forSeconds();
void forSeconds()
  if (key){
    lcd.print(key);
  if (key == '1')
    if (key == '2')
  if (key == '3')
   if (key == '4')
  if (key == '5')
   if (key == '6')
   if (key == '7')
   if (key == '8')
  if (key == '9')
                 if (key == '0')
                   if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    lcd.clear();
    lcd.setCursor(0,0);
        if (key == '*')
lcd.clear();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(seconds);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(1,1);
lcd.print(minutes);
lcd.print(seconds);
counter = 0;
secflag = 0;
lcd.clear();
delay(3000);
  if (key){
   if (key == '#')
    counter = 0;
    mymints = "";
    minutes = 0;
    mysecs = "";
    seconds = 0;
    secflag = 0;
    total_seconds = 0;
    lcd.clear();
    lcd.setCursor(0,0);
         //  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
    total_seconds = 0;
      lcd.clear();
i would test that the keypad code works without doing anything else.
void loop(){
  if (key != NO_KEY){
Once again, I have merged your posts due to them having too much overlap on the same subject matter @rdaffa59.
the keypad is still function because when i split the code, the timer work.
if you're so convinced, then you don't have a problem
i would test again
So far you have only given a very short information which is unprecise.
Your keypad does not jump into another function. It is your code.
which function is "another function" ????
with such few informations you force your potential helpers to collect almost every information themselves instead that you - the one who is asking for help serves this information.
I don't enjoy collecting information that could be easily given by the TO.
You
can
describe in much more detail what you are observing.
Or do the other users here have to transplant new eyes into your head?
A very important thing for successfully finishing coding is:
making visible what is really going on.
On microcontrollers the most convenient way to make visible what is really going on is to print to the serial monitor.
Now in a fast running function
you don't want to print hundreds of messages to the serial monitor each second.
There are several coding-techniques to slow down the printing.
