My 8 digit 7 segment display won't show my score anymore
I have a working code for my pinball machine to show the score when a button is hit but after I added my left side buttons, I can't seem to get the score to show up on my display anymore. I have gone through this code multiple times and I can't get it to work.
#define MAX7219_DIN 6  // set up for the display
#define MAX7219_CS  7
#define MAX7219_CLK 8
#define targetCount 8   // set up the number of targets in the target set
#define targetLed1 9
#define targetLed2 10
#define targetLed3 11
#define targetLed4 12
#define targetPin1 22
#define targetPin2 24
#define targetPin3 26
#define targetPin4 28
#define targetPin5 2
#define targetPin6 3
#define targetPin7 4
#define targetPin8 5
typedef struct target
  byte detectPin;
  byte ledPin;
  byte hit;
uint16_t score;       //this is the variable to store the score
target targets[targetCount] = {{targetPin1, 0}
                              ,{targetPin2, 0}
                              ,{targetPin3, 0}
                              ,{targetPin4, 0}
                              ,{targetPin5, 0}
                              ,{targetPin6, 0}
                              ,{targetPin7, 0}
                              ,{targetPin8, 0}
//right side of the board scoring info
  long last_rightBlue = 0;
  long last_rightGreen = 0;
  long last_rightRed = 0;
  long last_rightWhite = 0;
//left side of the board scoring info
  long last_leftBlue = 0;
  long last_leftGreen = 0;
  long last_leftRed = 0;
  long last_leftWhite = 0;
//top four rollover pins for the start of the game for a posible big score
  int last_topLeft = 0;
  int last_topMiddleLeft = 0;
  int last_topMiddleRight = 0;
  int last_topRight = 0;
// the setup function runs once when you press reset or power the board
  pinMode(targetPin1, INPUT);
  pinMode(targetPin2, INPUT);
  pinMode(targetPin3, INPUT);
  pinMode(targetPin4, INPUT);
  pinMode(targetPin5, INPUT);
  pinMode(targetPin6, INPUT);
  pinMode(targetPin7, INPUT);
  pinMode(targetPin8, INPUT);
     Serial.println("Ready to begin!");
  initialiseMAX7219();
  output(0x0f, 0x00); //display test register - test mode off
  output(0x0c, 0x01); //shutdown register - normal operation
  output(0x0b, 0x07); //scan limit register - display digits 0 thru 7
  output(0x0a, 0x0f); //intensity register - max brightness
  output(0x09, 0xff); //decode mode register - CodeB decode all digits
  output(0x08, 0x0c); //digit 7 (leftmost digit) data
  output(0x07, 0x0b);
  output(0x06, 0x0d);
  output(0x05, 0x0e);
  output(0x04, 0x08);
  output(0x03, 0x07);
  output(0x02, 0x06);
  output(0x01, 0x05); //digit 0 (rightmost digit) data
// the loop function runs over and over again forever
  detectCollision();
  redrawTargets();
  displayScore(score);
//This shows the score variable on the 8-digit display
void displayScore(int score)
  //calculate number of digits
  String myString = String(score);
  long numberOfDigits = myString.length();
    //clear unused digits
    for (long i = 8; i > numberOfDigits; i--)
      output(i, 0x0F);
    //write digits to the display
    for (long i = 1; i <= numberOfDigits; i++)
      output(i, myString[numberOfDigits-i]);
} //end of score display
//This checks if targets are hit
void detectCollision()
  long rightBlue = digitalRead(targets[0].detectPin);
  long rightGreen = digitalRead(targets[1].detectPin);
  long rightRed = digitalRead(targets[2].detectPin);
  long rightWhite = digitalRead(targets[3].detectPin);
  long leftBlue = digitalRead(targets[4].detectPin);
  long leftGreen = digitalRead(targets[5].detectPin);
  long leftRed = digitalRead(targets[6].detectPin);
  long leftWhite = digitalRead(targets[7].detectPin);
      //Check if target1 is hit
       if(rightBlue != last_rightBlue){
          if (rightBlue == HIGH) {    // Switch is pressed
        else {                // Switch is released and score added
          targets[0].hit = 1;
          Serial.print("Traff A!"); Serial.print("New score: ");
          Serial.print(score); Serial.print("!");Serial.println();
          score += 50;
          delay(50);
        delay(100);
        last_rightBlue = rightBlue;
      //Check if target2 is hit
       if(rightGreen != last_rightGreen){
          if (rightGreen == HIGH) {    // Switch is pressed
          targets[1].hit = 1;
          Serial.print("Traff B!"); Serial.print("New score: ");
          score += 25;
          delay(50);
        delay(100);
        last_rightGreen = rightGreen;
      //Check if target3 is hit
       if(rightRed != last_rightRed){
          if (rightRed == HIGH) {   // Switch is pressed
          targets[2].hit = 1;
          Serial.print("Traff C!"); Serial.print("New score: ");
          score += 100;
          delay(50);
        delay(100);
        last_rightRed = rightRed;
      //Check if target4 is hit
       if(rightWhite != last_rightWhite){
          if (rightWhite == HIGH) {   // Switch is pressed
          targets[3].hit = 1;
          Serial.print("Traff D!"); Serial.print("New score: ");
          score += 5;
          delay(50);
        delay(100);
        last_rightWhite = rightWhite;
        if(leftBlue != last_leftBlue){
          if (leftBlue == HIGH) {   // Switch is pressed
          targets[4].hit = 1;
          score += 30;
          delay(50);
        delay(100);
        last_leftBlue = leftBlue;
        if(leftGreen != leftGreen){
          if (leftGreen == HIGH) {   // Switch is pressed
          targets[5].hit = 1;
          score += 45;
          delay(50);
        delay(100);
        last_leftGreen = leftGreen;
        if(leftRed != last_leftRed){
          if (leftRed == HIGH) {   // Switch is pressed
          targets[6].hit = 1;
          score += 8;
          delay(50);
        delay(100);
        last_leftRed = leftRed;
        if(leftWhite != last_leftWhite){
          if (leftWhite == HIGH) {   // Switch is pressed
          targets[7].hit = 1;
          score += 11;
          delay(50);
        delay(100);
        last_leftWhite = leftWhite;
void redrawTargets()
  for(long i = 0; i < targetCount; i++)
    digitalWrite(targets[i].ledPin, 1-targets[i].hit);
void initialiseMAX7219()   //  MAX7219 7-Segment LED Display
  digitalWrite(MAX7219_CS, HIGH);
  pinMode(MAX7219_DIN, OUTPUT);
  pinMode(MAX7219_CS, OUTPUT);
  pinMode(MAX7219_CLK, OUTPUT);
//common routine to talkt o MAX7219
void output(byte address, byte data)
  digitalWrite(MAX7219_CS, LOW);
  shiftOut(MAX7219_DIN, MAX7219_CLK, MSBFIRST, address);
  shiftOut(MAX7219_DIN, MAX7219_CLK, MSBFIRST, data);
HI,
Can you post the working code that did display the score?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
so here is the code that I have working off of the pinball machine but if I upload it to the pinball machine this code doesn't even work for it. I have checked my wires and they are all good and in the correct port.
#define targetCount 4   // set up the number of targets in the target set
#define targetPin2 3
#define targetPin3 4
#define targetPin4 5
  byte detectPin;
  byte ledPin;
  byte hit;
                              ,{targetPin2, 0}
                              ,{targetPin3, 0}
                              ,{targetPin4, 0}
  int last_rightBlue = 0;
  int last_rightGreen = 0;
  int last_rightRed = 0;
  int last_rightWhite = 0;
  //   Serial.begin(9600);
  //   Serial.println("Ready to begin!");
  output(0x07, 0x0b);
  output(0x06, 0x0d);
  output(0x05, 0x0e);
  output(0x04, 0x08);
  output(0x03, 0x07);
  output(0x02, 0x06);
  detectCollision();
  redrawTargets();
  int numberOfDigits = myString.length();
    for (int i = 8; i > numberOfDigits; i--)
      output(i, 0x0F);
    for (int i = 1; i <= numberOfDigits; i++)
  int rightBlue = digitalRead(targets[0].detectPin);
  int rightGreen = digitalRead(targets[1].detectPin);
  int rightRed = digitalRead(targets[2].detectPin);
  int rightWhite = digitalRead(targets[3].detectPin);
          targets[0].hit = 1;
          score += 50;
        delay(100);
          targets[1].hit = 1;
          score += 25;
        delay(100);
          targets[2].hit = 1;
          score += 100;
        delay(100);
          targets[3].hit = 1;
          score += 5;
        delay(100);
  for(int i = 0; i < targetCount; i++)
Sorry but what do youi mean by,
If I upload it to the pinball machine this code doesn't even work for it.
Does that mean your "working" code doesn't work on your pinball machine as well?
Correct. It will work when I upload the code to my board that is off the pinball machine but won’t work when I upload it to the board that is on my pinball machine.
So you have two systems, on that is off the machine and on its own, and the one in the pinball.
What is the difference between the controller that is off the pinball and the one that is in it?
Have you checked supply voltages to the parts of your pinball using a DMM?
They are both the exact same board and are both brand new. I have checked the power coming in and I have started to notice every time I hit any of the targets the 8 digit display dims so could it be too much power going to the buttons
Controller ground connected to pinball machine ground?
Here are some pics of how all of my buttons are wired to the Arduino board
