Heres the code:
* TOOLCABIN LIGHT IN GOTHENBURG VERSION 0.90 DATE: 11. MARCH 2014
* Led dimmer using a TIP120 Darlington Transistor
* Supply voltage is from 14.4v battery and down/ LED build for 12V,
* But voltagedrop over Transistor and wires makes it ok.
* PIR-sensor power is fed from Arduino 5V / GND-pins.
* PIR output to digital pin (D3) - polled
* PIR can be retriggable or non retriggable
* LED switches on when PIR detects movement
* LED output will stay 'ON' until 5 sec of 'PIR silence'
* LED (transistor gate) MUST be connected to PWM pin. (D11)
* The Alarm is made from a Velleman MK174 where it is possible to record
* a custom message, mine is "Low Voltage, Please Recharge."
* The alarm is triggered from pin 7 wich goes HIGH for 10 ms and low again.
* There is a voltage divider (wiki that if you don't know") connected to
* pin A2 to keep track of the battery status, there might be a ampare
* sensor board on there sometime, but for now this is ok.
* This code can be drastically redused on volume - made for readability
// declare global constants
const byte led = 11; // connect to gate
const byte pir = 3; // PIR signal out
const byte alarm = 7; // The positive to the alarm trigger, have common ground whit power.
const byte turnOnTime = 1; // turn on/off time in seconds !(will be forced: 50 > time > 0)
const byte secondsToOff = 5; // seconds of 'silence' before "lights out" !! ALTER THIS VALUE
const boolean debug=false;
// declare global variables
boolean alreadyBlipped = true; //Have there been a "Low Voltage Alarm"?
boolean lightIsOn = false; // remember LED-status 'now'
unsigned long timeToTurnOff; // time when led will turn off
unsigned long timeNow; // current time
//Setup for measuring voltage
// number of analog samples to take per reading
#define NUM_SAMPLES 10
int sum = 0; // sum of samples taken
unsigned char sample_count = 0; // current sample number
float voltage = 0.0; // calculated voltage
// one time setup
// set status og used I/O-pins
pinMode(led,OUTPUT);
pinMode(pir,INPUT);
pinMode(alarm,OUTPUT);
// small functions and procedures - to make reading of main prog easier
boolean heWantsLightsOn()
return (digitalRead(pir)==HIGH);
void turnLightsOn(byte period)
// now the LED shall increase light intensity over "turnOnTime" seconds
long delayTime = period * 5 ;
for (byte i=0; i<255; i++)
analogWrite(led,i);
delay(delayTime);
digitalWrite(led,HIGH); // no PWM needed - turn on 100%
lightIsOn=true; // remember status
Serial.println("Light Is On"); //Tell me that the light is on
void turnLightsOff(byte period)
// now the LED shall decrease light intensity - slowly to zero
long delayTime = period*5 ;
for (byte i=254; i>0; i--)
analogWrite(led,i);
delay(delayTime);
digitalWrite(led,LOW); // no PWM needed - turn off
lightIsOn=false; // remember status
Serial.println("Light Is Off"); //Tell me that the light is off
alreadyBlipped = false;
timeNow=millis(); // note time now
if (heWantsLightsOn()) // if movement -> be light!
if (!lightIsOn) turnLightsOn(turnOnTime); // if still dark - be light! (else light were on already)
// set 'new' time for off -since you just told 'stay on for some mor minutes..)
timeToTurnOff=timeNow + secondsToOff * 1000; // set 'off-time' some minutes into the future (milliseconds used)
if (debug) Serial.println("renew for one minute");
// now test for "Elvis has left the building"
if (timeNow > timeToTurnOff) // is it time to turn off ??
if (lightIsOn) turnLightsOff(turnOnTime); // if light still are on: turn them off
// take a number of analog samples and add them up
while (sample_count < NUM_SAMPLES) {
sum += analogRead(A2);
sample_count++;
delay(100); //Wait 100ms before reading voltage again
// calculate the voltage
// use 5.0 for a 5.0V ADC reference voltage
voltage = ((float)sum / (float)NUM_SAMPLES * 4.73) / 1024.0;
// send voltage for display on Serial Monitor
// voltage multiplied by 3 when using voltage divider that
// divides by 3. 3 is the calibrated voltage divide
// value
Serial.print(voltage * 3);
Serial.println (" V");
sample_count = 0;
sum = 0;
if (voltage < 11.5 && lightIsOn == true && alreadyBlipped == false);
// if (lightIsOn == true && alreadyBlipped == false); //test if it's time to give the alarm
digitalWrite(alarm,HIGH); //open the trigger pin
delay(1); //let it stay on a bit
digitalWrite(alarm,LOW); //close it again
Serial.println("Low Voltage, Please Recharge"); //Tell me to recharge, but on-screen
alreadyBlipped = true; //Yes now the alarm has gone off!
//***************END***********************
My question is: why does this alarm goes off when the light is off?
and why does it triggers every time through the code and not only once after the light is 100% on?
and it keeps printing "Low voltage" way above 11.5 volts
I'm sure it's just a small stupid thing I missed...
