my arduino always error when uploading, it said "progammer is not responding"
help me ASAP… i dont know why my arduino isn’t working when i uploaded it. it always said like this
Arduino: 1.6.6 (Windows 8.1), Board: “Arduino/Genuino Uno”
Sketch uses 2,256 bytes (6%) of program storage space. Maximum is 32,256 bytes.
Global variables use 55 bytes (2%) of dynamic memory, leaving 1,993 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb5
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb5
“Show verbose output during compilation”
enabled in File > Preferences.
that text shown even when i uploaded the example of liquidCrystal. fyi i done the correct circuit based on youtube, books etc.
and i made a project “auto tank pump, use ultasonic sensor HC-SR04 based arduini uno”. here’s the code. when it was verified, that correct code, but cannot be uploading. hiks :sob:
#include <LiquidCrystal.h>
#include <Ultrasonic.h>
LiquidCrystal lcd(1, 2, 4, 5, 6, 7);
Ultrasonic ultrasonic(9,10);
#define relay
const int trigPin = 9;
const int echoPin = 10;
int relay1 = 2;
int distanceCm;
long duration, cm;
lcd.begin(16,2);
lcd.print("welcome to the auto-tank :)");
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(relay1, OUTPUT);
digitalWrite(relay1, HIGH);
digitalWrite(relay1, LOW);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distanceCm = duration*0.034/2;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Distance: ");
lcd.print(distanceCm);
lcd.print("  cm");
delay(10);
lcd.setCursor(0,1);
if(distanceCm<=30){
  lcd.setCursor(0,0);
  lcd.print("TANK EMPTY. TURN ON PUMP");
  long duration = ultrasonic.Timing();
  else {
  lcd.setCursor(0,0);
  lcd.print("TANK FULL. TURN OFF PUMP");
Have you ever been able to upload a program?
Have you selected the correct COM port and board type?
...R
Do you have anything plugged into D0 or D1 when trying to upload? If so unplug it and try again.
Robin2:
...R
yess, i was. correct COM and Board..... i'm stuck now huhuh
dannable:
no, i didn't plug it everywhere, i skip them
Mellmuc:
Have you tried the age-old trick of restarting your PC?
...R
Do you have it set as, Arduino as ISO in the bootloader?
