Alright I have my WiFi shield set up, running REST API.
This a simple example of the aREST Library for Arduino (Uno/Mega/Due/Teensy)
using the CC3000 WiFi chip. See the README file for more details.
Written in 2014 by Marco Schwartz under a GPL license.
// Import required libraries
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include <CC3000_MDNS.h>
#include <aREST.h>
#include <avr/wdt.h>
// These are the pins for the CC3000 chip if you are using a breakout board
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
#define pirPort 3000
// Create CC3000 instance
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2);
Adafruit_CC3000_Client client;
// Create aREST instance
aREST rest = aREST();
// Your WiFi SSID and password
#define WLAN_SSID "yourssid"
#define WLAN_PASS "pw"
#define WLAN_SECURITY WLAN_SEC_WPA2
#define SERVER "led.local"
#define PAGE "/pir"
#define HOME "localhost"
char server[] = "localhost:3000";
// The port to listen for incoming TCP connections
#define LISTEN_PORT 80
// Server instance
Adafruit_CC3000_Server restServer(LISTEN_PORT);
// DNS responder instance
MDNSResponder mdns;
// Variables to be exposed to the API
int localpin = 6;
void setup(void)
// Start Serial
// Init variables and expose them to REST API
pinMode(6, INPUT);
// Function to be exposed
rest.function("state",pirStatus);
rest.function("send",tcpSend);
rest.function("sled",ledSend);
// Give name and ID to device
rest.set_id("008");
rest.set_name("mighty_motion");
// Set up CC3000 and get connected to the wireless network.
if (!cc3000.begin())
while(1);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
while(1);
while (!cc3000.checkDHCP())
delay(100);
// Print CC3000 IP address. Enable if mDNS doesn't work
while (! displayConnectionDetails()) {
// Start multicast DNS responder
if (!mdns.begin("pir", cc3000)) {
while(1);
// Start server
restServer.begin();
Serial.println(F("Listening for connections..."));
// Enable watchdog
wdt_enable(WDTO_4S);
// Handle any multicast DNS requests
mdns.update();
// Handle REST calls
Adafruit_CC3000_ClientRef client = restServer.available();
rest.handle(client);
wdt_reset();
// Check connection, reset if connection is lost
if(!cc3000.checkConnected()){while(1){}}
wdt_reset();
// Print connection details of the CC3000 chip
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
return true;
// Custom function accessible by the API
int pirStatus(String) {
int state = digitalRead(6);
if (state == 1) {
Serial.print(F("Turn light on"));
if (state == 0) {
Serial.print(F("Turn light off"));
return state;
int tcpSend(String) {
unsigned long ip;
Serial.print(F("Locating test server..."));
cc3000.getHostByName((char *)server, &ip);
do {
client = cc3000.connectTCP(ip, 3000);
Serial.print(F("Connect"));
} while (false);
if(client.connected()) {
Serial.print(F("OK\r\nIssuing HTTP request..."));
if(cc3000.getHostByName("localhost", &ip)) {
client.fastrprint(F("GET "));
client.fastrprint(PAGE);
client.fastrprint(F(" HTTP/1.1\r\n"));
client.fastrprint(F("Host: ")); client.fastrprint(HOME); client.fastrprint(F("\r\n"));
client.println();
Serial.println("Should work");
Serial.println(F("Connection failed"));
int ledSend(String) {
Serial.println("Performing HTTP GET of: ");
Serial.println(SERVER);
client.println("GET /led/1 HTTP/1.1");
client.println("Host: ");
client.println(SERVER);
client.println("Connection: close");
unsigned long ip;
if(cc3000.getHostByName("led.local/led/1", &ip)) {
client = cc3000.connectTCP(ip, 80);
But I can't get the code to print past "Locating test server..." when I want the Arduino to GET localhost:3000/pir. I just want my Arduino to GET a webpage that I set up in localhost, but I'm not sure how the functionality or the entire library works. Does anyone know what I'm doing wrong?
