Sorry if my english is not really good: i'm french! I have a little problem with my Arduino IDE, it doesnt want to start. I'm actually working with ubuntu 11.04. I have all the requirements installed on my computers including the packages of arduino AND the IDE. I have an arduino UNO. I dont know what I can add for information... if you have questions for me to help for my problem, you can ask me and it will be a pleasure for me to answer to it!
What output do you get when you attempt to launch the IDE from a terminal command line? Also, have you inspected your log files for clues? Both will help you (and us, if you can post your results) figure out what is happening (also - and I haven't checked - have you posted this question to the Français international forum; you might have luck there and there wouldn't be any potential language issues to deal with, either - though your English is way better than my French!).
Thank you! When I start Arduino IDE in a terminal with the command: arduino, there’s a lot of errors that appear in. I can show you:
utilisateurn@ubuntu:~$ arduino
Could not createInput() for /home/utilisateurn/sketchbook/Sweep2/Sweep2.pde
ould not createInput() for /home/utilisateurn/sketchbook/Sweep2/Sweep2.pdejava.io.FileNotFoundException: /home/utilisateurn/sketchbook/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
ava.io.FileNotFoundException: /home/utilisateurn/sketchbook/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at java.io.FileInputStream.open(Native Method)rn/sketchbook/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at java.io.FileInputStream.open(Native Method)rn/sketchbook/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at java.io.FileInputStream.(FileInputStream.java:137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at java.io.FileInputStream.(FileInputStream.java:137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.core.PApplet.createInput(Unknown Source):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.core.PApplet.createInput(Unknown Source):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.core.PApplet.loadStrings(Unknown Source):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.core.PApplet.loadStrings(Unknown Source):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Base.loadFile(Base.java:2149)Source):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Base.loadFile(Base.java:2149)Source):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.SketchCode.load(SketchCode.java:251):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.SketchCode.load(SketchCode.java:251):137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.SketchCode.(SketchCode.java:79)137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.SketchCode.(SketchCode.java:79)137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Sketch.load(Sketch.java:192).java:79)137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Sketch.load(Sketch.java:192).java:79)137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Sketch.(Sketch.java:140)ava:79)137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Sketch.(Sketch.java:140)ava:79)137)/Sweep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Editor.handleOpenInternal(Editor.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Editor.handleOpenInternal(Editor.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Editor.(Editor.java:308)or.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Editor.(Editor.java:308)or.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Base.handleOpen(Base.java:699)or.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Base.handleOpen(Base.java:699)or.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Base.restoreSketches(Base.java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Base.restoreSketches(Base.java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Base.(Base.java:277)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Base.(Base.java:277)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Base.main(Base.java:190)7)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Base.main(Base.java:190)7)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)Exception in thread “main” n(Base.java:190)7)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)java.lang.NullPointerExceptionase.java:190)7)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
ava.lang.NullPointerExceptionase.java:190)7)java:360)va:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.SketchCode.load(SketchCode.java:253)a:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.SketchCode.load(SketchCode.java:253)a:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.SketchCode.(SketchCode.java:79):2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.SketchCode.(SketchCode.java:79):2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Sketch.load(Sketch.java:192).java:79):2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Sketch.load(Sketch.java:192).java:79):2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Sketch.(Sketch.java:140)ava:79):2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
at processing.app.Sketch.(Sketch.java:140)ava:79):2114)weep2/Sweep2.pde (Erreur d’entrée/sortie) at processing.app.Editor.handleOpenInternal(Editor.java:2114)weep2/Sweep2.pde (Erreur d’entrée/sortie)
