my arduino program is not giving any error still can not get data on web page
hello,
i am trying to upload my arduino uno data on my web page using sim900A module with arduino uno.
and some times it prints success message (200) on serial monitor .
but still not getting data on my web page
here is my code
send data to webpage.txt (2.45 KB)
here is you code using code tags and properly indented for everyone to read without clicking
#include <SoftwareSerial.h>
//#include "test_4july.h"
SoftwareSerial myGsm(2, 3);
char frame[200];
char aux_str[30];
char  latitude[15];
int longitude = 2;
int altitude = 3;
//char url[] = "https://devanshipatel.000webhostapp.com/vts/vts/get_link.php";
  myGsm.begin(9600);
  //  myGsm.println("AT+CGPSIPR=9600");
  // delay(200);
  // printSerialData();
  //  myGsm.println("AT+CGPSPWR=1");
  // delay(200);
  //  myGsm.println("AT+CGATT=1");
  // delay(200);
  delay(200);
  printSerialData();
  myGsm.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR,connection type is GPRS
  printSerialData();
  myGsm.println("AT+SAPBR=3,1,\"APN\",\"UninorGPRS\"");//setting the APN,2nd parameter empty works for all networks
  delay(5000);
  printSerialData();
  myGsm.println("AT+SAPBR=3,1,\"USER\",\"\"");//setting the APN,2nd parameter empty works for all networks
  delay(5000);
  printSerialData();
  myGsm.println("AT+SAPBR=3,1,\"PWD\",\"\"");//setting the APN,2nd parameter empty works for all networks
  delay(5000);
  printSerialData();
  myGsm.println("AT+SAPBR=1,1");
  delay(10000);
  printSerialData();
  myGsm.println("AT+SAPBR=2,1");//setting the APN,2nd parameter empty works for all networks
  delay(5000);
  printSerialData();
  //myGsm.println();
  myGsm.println("AT+HTTPINIT");
  delay(10000);
  printSerialData();
  myGsm.println("AT+HTTPPARA=\"CID\",1");
  delay(10000);
  printSerialData();
  myGsm.println("AT+HTTPPARA=\"URL\",http://www.drpinventions.com/get_link.php?latitude=2");// setting the httppara,
  //the second parameter is the website from where you want to access data
  printSerialData();
  //   myGsm.println("AT+HTTPDATA=192,10000");
  // delay(10000);
  myGsm.println("AT+HTTPACTION=0");//submit the GET request
  delay(1000);//the delay is important if the return datas are very large, the time required longer.
  printSerialData();
  //delay(5000);
  myGsm.println("AT+HTTPREAD");// read the data from the website you access
  delay(10000);
  printSerialData();
  myGsm.println("");
  myGsm.println("AT+HTTPTERM");// terminate HTTP service
  printSerialData();
void printSerialData()
  while (myGsm.available() != 0)
    Serial.write(myGsm.read());
don’t you need quotes around the URL too in the HTTPPARA AT command?
AT+HTTPPARA="URL",[color=red]"[/color]http://xxxx[color=red]"[/color]
  printSerialData();
this is actually a poor way of handling the answer… while you wait 1 second the incoming buffer might fill in and after 64 chars you’ll start loosing data… also the way you print the data from the buffer never guarantees you print the full response if you empty the buffer faster than the data comes in (which is likely at 9600 bauds)
read Serial Input Basics to get a view on how to best handle the Serial port
thank you for reply
do you know any appropriate way to send data on web page using sim900A ?
because i have tried TCP protocol
but my gprs send "ERROR" on AT+CIPMUX=0 and all TCP related AT commands.
and i want to send mobile data on server so WIFI and Ethernet shield is not possible for me.
please give me any suggestion to send data ....
is your SIM ok for DATA ?
yes
does it register itself on the carrier network? is the basic stuff (calls, SMS) working? (cf this tutorial for example, there are plenty on line) then you can watch this one for HTTP commands
i have tested call and sms , both are working perfectly
SIM900 GPRS HTTP AT Commands - Embedded World in this it is posting text file and i want to post variable
and i have read data on web page using http URL , it is also working
i have screen shot of that
i have gone through your instructions on http://www.instructables.com/id/GSM-SIM900A-With-Arduino/
and call and sms are working ..
please give me suggestion in this for same URL only sometimes i am getting (200) message on serial monitor
well in your code you do  myGsm.println("AT+HTTPPARA=\"URL\",http://www.drpinventions.com/get_link.php?latitude=2");// setting the httppara,I think you are missing double quotes for the URL so would need to be
  myGsm.println("AT+HTTPPARA=\"URL\",\"http://www.drpinventions.com/get_link.php?latitude=2\"");// setting the httppara,
then if you don't want to have the 2 as a static element but coming from a variable, that's easy, you just need to split the print into chucnks
int variable = 22; // the value you want to pass to your PHP script
myGsm.print("AT+HTTPPARA=\"URL\",\"http://www.drpinventions.com/get_link.php?latitude="); // this is print, not println --> No LN at the end of print !
myGsm.print(variable);// this is print, not println --> No LN at the end of print !
myGsm.println("\"");// HERE it's PRINTLN as this is the end of the command, so you want the "\r\n" sent to mark the end of the AT command
AT+CGATT=1
OK
AT+SAPBR=3,1,"CONTYPE","GPRS"
OK
AT+SAPBR=3,1,"APN","UninorGPRS"
OK
AT+SAPBR=3,1,"USER",""
OK
AT+SAPBR=3,1,"PWD",""
OK
AT+SAPBR=1,1
ERROR
AT+SAPBR=2,1
+SAPBR: 1,1,"10.100.18.45"
OK
AT+HTTPINIT
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPPARA="URL", "http://www.drpinventions.com/get_link.php?lAT+HTTPACTION=0
OK
AT+HTTPREAD
OK
+HTTPACTION:0,603,0
i am getting this in serial monitor
AT+SAPBR=1,1
AT+SAPBR=2,1
AT+SAPBR=1,1 --> //Enable bearer 1
AT+SAPBR=2,1 --> //Check whether bearer 1 is open
so seems it can't enable bearer 1 (probably the error is because it's already open)
(usually one set the necessary APN through AT+SAPBR --> is that already done?)
this is definitely not well formed
AT+HTTPPARA="URL", [color=red]"[/color]http://www.drpinventions.com/get_link.php?[color=red]lAT+HTTPACTION=0[/color]
it prints every time like that
kajal27:
well what are you sending?
code:
//#include “test_4july.h”
SoftwareSerial myGsm(2,3);
char frame[200];
char aux_str[30];
char latitude[15];
int longitude = 2;
int altitude = 3;
//char url = “https://devanshipatel.000webhostapp.com/vts/vts/get_link.php”;
myGsm.begin(9600);
// myGsm.println(“AT+CGPSIPR=9600”);
// delay(200);
// myGsm.println(“AT+CGPSPWR=1”);
// delay(200);
// myGsm.println(“AT+CGATT=1”);
// delay(200);
delay(200);
printSerialData();
myGsm.println(“AT+SAPBR=3,1,“CONTYPE”,“GPRS””);//setting the SAPBR,connection type is GPRS
printSerialData();
myGsm.println(“AT+SAPBR=3,1,“APN”,“UninorGPRS””);//setting the APN,2nd parameter empty works for all networks
delay(5000);
printSerialData();
myGsm.println(“AT+SAPBR=3,1,“USER”,”"");//setting the APN,2nd parameter empty works for all networks
delay(5000);
printSerialData();
myGsm.println(“AT+SAPBR=3,1,“PWD”,”"");//setting the APN,2nd parameter empty works for all networks
delay(5000);
printSerialData();
// myGsm.println(“AT+SAPBR=1,1”);
// delay(10000);
myGsm.println(“AT+SAPBR=2,1”);//setting the APN,2nd parameter empty works for all networks
delay(5000);
printSerialData();
//myGsm.println();
myGsm.println(“AT+HTTPINIT”);
delay(10000);
printSerialData();
myGsm.println(“AT+HTTPPARA=“CID”,1”);
delay(10000);
printSerialData();
myGsm.println(“AT+HTTPPARA=“URL”, “http://prashantbpatel.com/sample.txt””); // setting the httppara, the second parameter is the website from where you want to access data
// myGsm.print(latitude);
// myGsm.println(""");
delay(10000);
printSerialData();
// myGsm.println(aux_str, "AT+HTTPPARA=“URL”,"http://www.drpinventions.com/get_link.php?");
// Serial.print(aux_str);
// myGsm.println(frame, “latitude=%d&longitude=%d&altitude=%d”,latitude ,longitude, altitude);
// myGsm.println(“AT+HTTPDATA=192,10000”);
// delay(1000);
myGsm.println("");
myGsm.println(“AT+HTTPACTION=0”);//submit the GET request
delay(10000);//the delay is important if the return datas are very large, the time required longer.
printSerialData();
//delay(5000);
myGsm.println(“AT+HTTPREAD”);// read the data from the website you access
delay(10000);
printSerialData();
// myGsm.println("");
// delay(10000);
// myGsm.println(“AT+HTTPTERM”);// terminate HTTP service
while(myGsm.available()!=0)
what if you try just this
//set up GPRS, connection type
printSerialData();
// Handle the APN
printSerialData();
//tries to connect to GPRS
myGsm.println("AT+SAPBR=1,1"); //Enable bearer 1
delay(200);
printSerialData();
myGsm.println("AT+SAPBR=2,1"); //Check whether bearer 1 is open
delay(200);
printSerialData();
// initialise embedded HTTP ruttine
delay(2000);
printSerialData();
// set the HTTP session
printSerialData();
// set the HTTP URL
myGsm.println("AT+HTTPPARA=\"URL\",\"http://prashantbpatel.com/sample.txt\"");
// start the session
printSerialData();
// read the data from the HTTP server
// that's because you have a crapy way of reading the Serial line..
// an attempt to read for a bit longer
for (int i=0; i<100; i++) {
   printSerialData();
   delay(1):
// ends the connexion with the HTTP server
delay(100);
myGsm.printlnln();
printSerialData();
now i have solved this (AT+HTTPPARA=“URL”, "http://www.drpinventions.com/get_link.php?lAT+HTTPACTION=0)
AT+CGATT=1
OK
OK
OK
AT+SAPBR=3,1,“USER”,""
OK
AT+SAPBR=3,1,“PWD”,""
OK
AT+SAPBR=2,1
+SAPBR: 1,1,“10.100.18.45”
OK
AT+HTTPINIT
ERROR
AT+HTTPPARA=“CID”,1
OK
OK
AT+HTTPACTION=0
OK
AT+HTTPREAD
OK
+HTTPACTION:0,603,0
try with the following function to print out the Serial output - whilst not perfect it will at least give you a 2 second timeout and try for a while to read from the Serial line
  const unsigned long timeout = 2000ul;
  unsigned long startChrono = millis();
  while (millis() - startChrono <= timeout) {
    if (myGsm.available()) {
      startChrono = millis(); // reset the timeOut
    delayMicroseconds(10); // sometimes Sofwtare Serial does not like banging at it too fast
in which case you don’t need the
   printSerialData();
   delay(1):
at the end of my code above.
→ please tell me if you used that code… can’t find out what you are trying unless you post your code (and get rid of things commented out)
AT+HTTPACTION = 0
is not executing
AT+CGATT=1
OK
OK
OK
AT+SAPBR=1,1
OK
AT+SAPBR=2,1
+SAPBR: 1,1,"10.102.55.40"
OK
AT+HTTPINIT
ERROR
AT+HTTPPARA="CID",1
OK
AT+HTTPPARA="URL","http://prashantbpatel.com/sample.txt"
AT+HTAT+HTTPREAD
OK
AT+HTTPTERM
OK
