I just got myself an Arduino uno and all od the Pins don't work. I saw a Black component under the built in LED and it is offset and i think that this is causing the problem. Can someone help?
Certainly at least one problem…
The resistor array marked 102, has not been placed properly.
There’s a good chance there could be other assembly problems.
definitely an issue indeed, it should look like this
as it's an original board, you should return it for a replacement, not try to fix it yourself and void the warranty
Fixing it yourself really requires a hot-air rework station and the skills to go with it... Otherwise returning is best. It's clearly faulty from a visual inspection.
Curious!
"RN2" connects the three nearby LEDs and is involved in the reset circuitry, but I cannot really see why the accidental connection of the reset pull-down to the "TX" led would interfere with normal operation once the 16U2 was initialised and pin 13 defined OUTPUT!
Congrats for finding it yourself. A lot of people would just panic and act helpless.
If you bought the board directly from Arduino, contact the Tech Support with https://www.arduino.cc/en/contact-us/. Give a clear and short detail of the issue with pcitures and your purchase invoice attached.
However, if bought from an authorised distributor or retailer, ask them for a replacement.
