My Arduino Uno L Led keep Turn on but i can still upload code
My arduino is stop working 2 days ago then i flash the bootloader and it works but The L LED Is Keep Turned on
Anyone can help?
The L led is the led connected to pin 13; it's quite normal that that is on if you don't switch it specifically off in code.
A simple pinMode(LED_BUILTIN, OUTPUT) will probably already be enough although it's better to add a digitalWrite(LED_BUILTIN, LOW) as well.
Im using the pwm Code but its still on :frowning:
Pin 13 on an Uno is not a PWM pin.
What is the pwm code? Please post the code here using code tags.
To use code tags
Type
** **[code]** **
Paste your code after that
Type
** **[/code]** **
I know 13 is not a PWM pin im using timer1 or 9 and 10 it keep turned on
Just upload the blink example to see if it's working .
the blink does working
So what's the problem?
The L LED is annoyingwhen it keeps turn on if use another code :frowning:
Then switch it off in your code.
