my ardunio has an error after entering the wrong servo cable to 5v and gnd
-and the SB device not recognized
If you disconnect the servo altogether from the UNO, can you upload code? It it found at the COM port of your computer?
I didn't enter the code into my Arduino because the USB is not recognized and the port is not read by my computer after I inserted the wrong servo cable into the Arduino
What is the wrong cable? A better description is probably needed to determine exactly what happened. Post a photo of a drawing with the incorrect connections and voltages involved.
I suspect that we are going to be invited for a funeral.
Most likely the USB to TTL converter IC has been damaged due to an overcurrent flow/short circuit.
Most likely due to plugging the servo cable in with reverse polarity.
yes, right. Now, if the main Atmega328P is OK, you can use this board with a separate USB to TTL converter. If that does not work, I'm afraid that you have to toss it away.
