Good day Mam/Sir
I am trying to create a device using Arduino pro mini that once the button were pushed it will trigger the buzzer and emergency text message will be sent.
My code is :
#include <NeoSWSerial.h>
#include <AltSoftSerial.h>
NeoSWSerial MOD_GPS(2, 3);
#include <TinyGPS.h>
TinyGPS gps;
AltSoftSerial MOD_SIM800L(8, 9);
const byte armButtonPin = 6; // Alarm on button
const byte disarmButtonPin = 7; // Alarm off button
const byte Buzzer = 12; //Buzzer
float latitude, longitude;
unsigned long age;
unsigned long chars;
MOD_SIM800L.begin(9600);
MOD_GPS.begin(9600);
pinMode(armButtonPin, INPUT);
pinMode(disarmButtonPin, INPUT);
pinMode(Buzzer, OUTPUT); // Declare the push Buzzer pin as OUTPUT
//Print on serial monitor:
Serial.println("");
Serial.println("Start");
Serial.println("Sending Data ... ");
Serial.println("");
bool newData = false;
unsigned short sentences, failed;
for (unsigned long start = millis(); millis() - start < 1000;)
while (MOD_GPS.available())
char c = MOD_GPS.read();
if (gps.encode(c))
newData = true;
if (newData) {
gps.f_get_position(&latitude, &longitude, &age);
Serial.print(("Latitud/Longitud: "));
Serial.println(" ");
Serial.println(latitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : latitude, 7); Serial.println(", ");
Serial.println(longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : longitude, 7);
gps.stats(&chars, &sentences, &failed);
bool armbuttonState = digitalRead(armButtonPin);
if (armbuttonState == HIGH)
Serial.println("Configuration Done!");
Serial.println("Sending SMS...");
Serial.print("MeMOD_GPSage Sent!");
MOD_SIM800L.println("AT+CMGF=1\r\n");
delay(100);
MOD_SIM800L.println("AT+CMGS=\"+628XXXXXXX\"\r\n");
delay(100);
MOD_SIM800L.println("\nI'm in Trouble! I need your help!!");
MOD_SIM800L.println("\nhttp://maps.google.com/maps?q"); MOD_SIM800L.print(longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : latitude, 5); MOD_SIM800L.print(","); MOD_SIM800L.print(longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : longitude, 5);
//Enviar Ctrl+Z
MOD_SIM800L.write((char)26);
digitalWrite(Buzzer, HIGH); //make a sound
bool disarmbuttonState = digitalRead(disarmButtonPin);
if (disarmbuttonState == HIGH)
digitalWrite(Buzzer, LOW); //silent
delay(100);
exit (0);
*sorry if its too messy .
It has 2 button that serves as an on/off switch for the buzzer, once I pushed the on switch the buzzer will alarm then a text will be sent unless I pushed the off switch the buzzer will continuously trigger a sound. I dont know how to do these using one switch only so I tried if it will work on two buttons like I what I saw on Google.
The problem is that after I inserted my code for button and buzzer it doesn't work anymore. Can anyone tell me what went wrong? I will really appreciate your help. Thank you
