Hello everyone, it is my first time using Arduino (uno) for school project and they want a c program to communicate with it via serial, and after I came up with a C code after reading countless docs and tutorials.
The problem is that if I upload code to the Arduino and then try to communicate via c program the RX led blinks but I doesn't do nothing, I have to open the serial monitor on the IDE and close right after and then It works.
I already have read so many other posts with this issue and I suppose the solution was something with DTR and RTS, but after doing that stuff it still does not work...
For now I'm just sending 1 byte, letter 'A', and the c program works fine after opening and closing serial monitor, other thing I noticed is that after that I need to send 'A' two times for it to work, only sending 'A' one time does nothing too.
I appreciate any help,
Thanks
.ino code
#include <SoftwareSerial.h>
#include <HardwareSerial.h>
// Pins
int pinLed0 = LED_BUILTIN;
int pinLed1 = 12;
int pinLed2 = 13;
// Serial stuff
int dataLenght = 1;
char szBuff[2];
// Put your setup code here, to run once:
// Initialize serial
Serial.setTimeout(1000);
// Initialize the pins as an output
pinMode(pinLed0, OUTPUT);
pinMode(pinLed1, OUTPUT);
pinMode(pinLed2, OUTPUT);
// Put your main code here, to run repeatedly:
if (Serial.available() > 0) {
// Read bytes sent
Serial.readBytes(szBuff, dataLenght);
// Control led based on data sent
if (szBuff[0] == 'A') digitalWrite(pinLed1, HIGH);
else digitalWrite(pinLed1, LOW);
digitalWrite(pinLed2, HIGH);
delay(100);
digitalWrite(pinLed2, LOW);
delay(100);
.c code
#include <Windows.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <process.h>
#include <fileapi.h>
HANDLE hSerial;
DCB dcbSerialParams;
COMMTIMEOUTS timeouts;
DWORD dwBytesWrite;
int dataLenght = 1;
char szBuff[2];
char readConsole[2];
char lastError[1024];
char bytesWriten[1024];
int main() {
// Serial handle
hSerial = CreateFile(L"\\\\.\\COM3", GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING, 0, 0);
if (hSerial == INVALID_HANDLE_VALUE) {
if (GetLastError() == ERROR_FILE_NOT_FOUND) {
printf("!Serial port error, port does not exist.\n"); // Serial port does not exist. Inform user.
printf("!Serial error has occurred.\n");
// DCB configuration.
if (!GetCommState(hSerial, &dcbSerialParams)) {
printf("!Error getting state.\n"); // Error getting state.
SecureZeroMemory(&dcbSerialParams, sizeof(DCB));
dcbSerialParams.DCBlength = sizeof(DCB);
dcbSerialParams.BaudRate = CBR_9600; // Baud rate
dcbSerialParams.ByteSize = 8; // Data size, xmit and rcv
dcbSerialParams.Parity = NOPARITY; // Parity bit
dcbSerialParams.StopBits = ONESTOPBIT; // Stop bit
// Setting the DTR to Control_Enable ensures that the Arduino is properly reset upon establishing a connection
dcbSerialParams.fDtrControl = DTR_CONTROL_ENABLE;
dcbSerialParams.fRtsControl = RTS_CONTROL_DISABLE;
dcbSerialParams.fDsrSensitivity = FALSE;
PurgeComm(hSerial, PURGE_RXCLEAR);
PurgeComm(hSerial, PURGE_TXCLEAR);
// We wait 2 seconds as the arduino board will be reseting
Sleep(2000);
if (!SetCommState(hSerial, &dcbSerialParams)) {
printf("!Error setting state.\n"); // Error setting state.
// Timeout configuration.
timeouts.ReadIntervalTimeout = 1000;
timeouts.ReadTotalTimeoutConstant = 1000;
timeouts.ReadTotalTimeoutMultiplier = 1000;
timeouts.WriteTotalTimeoutConstant = 1000;
timeouts.WriteTotalTimeoutMultiplier = 1000;
if (!SetCommTimeouts(hSerial, &timeouts)) {
printf("!Timeout error occurred.\n"); // Timeout error occureed.
//// OpenCommPort
while (1) {
printf("Write A or B\n");
fflush(stdin);
fflush(stdout);
gets(&readConsole);
strcpy_s(&szBuff, sizeof(szBuff), readConsole);
printf("You wrote: %s\n", szBuff);
if (!WriteFile(hSerial, (void*)szBuff, dataLenght, &dwBytesWrite, 0)) {
printf("!Write error occurred.\n"); // Write error occurred.
CloseHandle(hSerial);
