My car cannot turn when I want
Hi,it's me again :smiley: !
So I have a final problem with my car. It advances well, it stops well, everything is good. However, I want my car to turn if an other vehicule infront turns also. Nothing happens when this condition arrives.
I have two sensors, a Ping and a MaxSonar EZ2. They are set on both sides of the car. One on each. So in my program, I said that if per example the MaxSonar detects something in a range of 50cm AND the Ping doesn't detect anything, my car should turn right. However, nothing happens.
I placed an object at this position but nothing happens.
Sonar: http://imgur.com/SIUsiFW
Ping: Imgur: The magic of the Internet
And my code:
 if(cm>50 and valeurPing<50)
      if(cm<50 and valeurPing>50)
    myservo.write(0);
    myservo.write(70);
digitalWrite(motor,HIGH);
delay(150);
digitalWrite(motor,LOW);
delay(300);
cm= Sonar and ValeurPing = Ping
if both Sonar and Ping don't detect anything in a range of 50cm, it advance and if they do, it stops so there's no problem there. Also,the servo works fine because I tested the example sweep and it worked.
What's wrong? Thanks
What's wrong?
You didn't post your code, but what values are going to satisfy these conditions
oh forget the if(cm>50 and valeurPing<50) it's an error of copy paste. If you want my whole code:
const int pingPin = 7;
int moteur= 3;
#include <Servo.h>
int rouge = 6;
int vert = 5;
int bleu= 4;
Servo myservo;
int pos = 0;
float Inch=0.00;
float cm=0.00;
int SonarPin=A1;
int  sensorValue;
pinMode(moteur, OUTPUT);
pinMode(rouge, OUTPUT);
pinMode(vert,OUTPUT);
pinMode(bleu,OUTPUT);
myservo.attach(9);
long int acquisitionPing(void){
    long int duration;
    pinMode(pingPin, OUTPUT);
    digitalWrite(pingPin, LOW);
    delayMicroseconds(2);
    digitalWrite(pingPin, HIGH);
    delayMicroseconds(5);
    pinMode(pingPin, INPUT);
    duration = pulseIn(pingPin, HIGH);
    return duration / 29 / 2;
long int acquisitionMaxSonar(void){
  sensorValue=analogRead(SonarPin);
delay(50);
Inch= (sensorValue*0.497);
cm=Inch*2.54;
   long int valeurPing;
   long int valeurSonar;
    // on fait l'acquisition des senseurs
   valeurPing = acquisitionPing();
   valeurSonar = acquisitionMaxSonar();
  // on traite les informations recueillies
  // par exemple
Serial.print(cm);
Serial.println('cm');
  if (valeurPing>50 and cm > 50)
digitalWrite(rouge,HIGH);
digitalWrite(rouge,LOW);
digitalWrite(vert,HIGH);
digitalWrite(vert,LOW);
digitalWrite(bleu,HIGH);
digitalWrite(bleu,LOW);
    myservo.write(70);
digitalWrite(moteur,HIGH);
delay(150);
digitalWrite(moteur,LOW);
delay(300);
if (valeurPing < 50 and cm <50 )
      myservo.write(70);
    analogWrite(moteur,0);
    myservo.write(179);
    myservo.write(70);
delay(150);
delay(300);
delay(500); }
 myservo.write(0);
    myservo.write(70);
delay(150);
delay(300);
My eyes pleaded with me to reformat your code
int moteur= 3;
#include <Servo.h>
int rouge = 6;
int vert = 5;
int bleu= 4;
Servo myservo;
int pos = 0;
float Inch=0.00;
float cm=0.00;
int SonarPin=A1;
int  sensorValue;
  myservo.attach(9);
  long int duration;
  delay(50);
  cm=Inch*2.54;
  // par exemple
  Serial.print(cm);
    myservo.write(70);
    delay(150);
    delay(300);
      myservo.write(70);
      myservo.write(179);
      myservo.write(70);
      delay(150);
      delay(300);
      myservo.write(0);
      myservo.write(70);
      delay(150);
      delay(300);
Allright I will remove the french :smiley:
int moteur= 3;
#include <Servo.h>
Servo myservo;
int pos = 0;
float Inch=0.00;
float cm=0.00;
int SonarPin=A1;
int  sensorValue;
pinMode(motor, OUTPUT);
myservo.attach(9);
    long int duration;
delay(50);
cm=Inch*2.54;
   long int valuePing;
   valuePing = acquisitionPing();
  if (valuePing>50 and cm > 50)
    myservo.write(70);
delay(150);
delay(300);
if (valuePing < 50 and cm <50 )
      myservo.write(70);
    analogWrite(motor,0);
  if(cm>50 and valuePing<50)
    myservo.write(179);
    myservo.write(70);
delay(150);
delay(300);
  if(cm<50 and valuePing>50)
 myservo.write(0);
    myservo.write(70);
delay(150);
delay(300);
So I slightly modified the format of your code, and removed some statements so you can see the overall flow and perhaps notice what your problem is:
  if (valeurPing>50 and cm > 50) {
    if (valeurPing < 50 and cm <50 ) {
    if(cm>50 and valeurPing<50) {
    if(cm<50 and valeurPing>50) {
Take a careful look at the (formatted) code... can you see the important difference between the 4 "if" statements? And see how correctly formatting your code can help you find problems?
Hope this helps,
Brad
KF7FER
Yes I see... there was a } at the wrong place... It's just a wrong typing. I made this mistake when I modified my code. But when I tested my car, the } was at the good place.
Or maybe you are talking about something else?
