I Hope you guys can help me.
I’m working on a cheap solar logger (10-20$) that counts pulses from a kWh meter.
The basic functions are:
- Read pulses from the kWh meter
- Log these pulses into a CSV
The advanced functiontionalities are:
- Logging temperature sensors
- Managing the inverter temperature according to the temp sensors
- Transmitting results over RF
I was using the default SD.h library but after the project grew it started to fail on me (not enough SRAM). So I switched to TinyFAT since it was much less SRAM hungry
I’m just having problems getting TinyFAT to work. It always returns an error (ERROR_MBR_SIGNATURE). I’m using a 2GB SD card formated with SDformatter. If i use the examples that come with TinyFAT everything works but when I use my own project I’m unable to complete the setup.
Small remark: I’ve been running the examples on a Arduino UNO. My project uses a Stand alone Atmega328 on a breadboard.
This is the schematic:
My question(s):
- Why won’t TinyFAT start?
- Any tips on reducing the SRAM usage?
- If you any other questionable coding please let me know.
I attached the full .ino to this post.
This is the setup part:
ERROR CODES:
# blinks Error
1 SD card failed, or not present
2 Reading time failed
3 Unable to write to file
4 Error while Sending RF (message too long)
5 Error reading file from SD for daily result
6 SD Error reading MBR
7 SD MBR Signature error
8 SD Unsupported filesystem
9 SD Error reading Boot Sector
10 SD Boot Sector Signature error
11 SD Unknown error
#include <DS3231.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <MemoryFree.h>
#include <VirtualWire.h>
#include <tinyFAT.h>
#include <avr/pgmspace.h>
//Pin settings
//SD
const byte chipSelectPin = 10;
//LEDs
const byte errorLedPin = 4;
const byte confirmLedPin = 5;
//RF module
const byte rfPin = 6;
//Fan Switching
const byte fanPin = 3;
//Interrupt Variables
const byte interruptPinS0 = 2;
//Daily results button
const byte dailyResultsButton = 8;
//Settings
//DS3231 variables
DS3231 Clock;
byte Year, Month, Date, DoW, Hour, Minute, Second;
//Confirm led variables
const byte confirmLedInterval = 50;
const byte errorLedInterval = 250;
volatile byte confirmLedBlinks = 0;
byte confirmLedState = LOW;
unsigned long confirmLedPreviousMillis = 0;
const byte minimumInteruptDifference = 200;
volatile unsigned long previousInterruptMillis = 0;
volatile unsigned int S0Counter = 0;
volatile unsigned int DailyProd = 0;
volatile boolean broadcastPulse = false;
//Temperatures variables
#define ONE_WIRE_BUS 7
#define TEMPERATURE_PRECISION 12
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float temp1, temp2, temp3;
boolean getTemps = true;
//Fan variables
const byte fanStartTemp = 25;
const byte fanMaxTemp = 30;
const byte fanMinSpeed = 100;
byte fanCurrentSpeedPCT = 0;
//Log variables
byte bytLogIntervalMinutes = 5;
byte maxlogsWithZeroPulses = 5;
const char chrSeparator = ';';
//CSV character
byte bytLastLogMinute = 0;
byte logsWithZeroPulses = 100;
//Power variables
const long millisinHour = 3600000;
volatile unsigned int currentPower = 0;
//SD variables
byte res;
int verboseError(byte err)
switch (err)
case ERROR_MBR_READ_ERROR:
return 6;
case ERROR_MBR_SIGNATURE:
return 7;
case ERROR_MBR_INVALID_FS:
return 8;
case ERROR_BOOTSEC_READ_ERROR:
return 9;
case ERROR_BOOTSEC_SIGNATURE:
return 10;
default:
return 11;
//Set pinmodes
pinMode(errorLedPin,OUTPUT);
pinMode(confirmLedPin,OUTPUT);
pinMode(chipSelectPin, OUTPUT);
pinMode(fanPin, OUTPUT);
pinMode(interruptPinS0, INPUT);
pinMode(rfPin,OUTPUT);
pinMode(dailyResultsButton,INPUT);
//RF module
vw_set_tx_pin(rfPin);
vw_set_ptt_inverted(true);
vw_setup(2000);
printMemoryUsage();
//Start wire for DS3221
Wire.begin();
//DS18B20
sensors.begin();
getNewTemps();
// Start SD
file.setSSpin(chipSelectPin);
byte res=file.initFAT(SPISPEED_MEDIUM);
if (res!=NO_ERROR)
errorLoop(verboseError(res), false);
//Attach interupt to interupt pin 0 = pin 2 on the arduino
attachInterrupt(0, S0interrupt, FALLING);
//High Frequency pwm on pin 3 and 11 (only 3 is used)
TCCR2B = TCCR2B & 0b11111000 | 0x01;
confirmLedBlinks++;
printMemoryUsage();
Solarlogger_2013_08_18.ino (14.2 KB)
