#include <Keypad.h> //Include Keypad and servo library
#include <Servo.h>
Servo servoblue; //The servo is called „servoblue“ from now on
char* password = "123";
int position = 0;
const byte ROWS = 4; //In this two lines we define how many rows and columns
const byte COLS = 3; //our keypad has
char keys[ROWS][COLS] = { //The characters on the keys are defined here
{'#', '0', '*'},
{'9', '8', '7'},
{'6', '5', '4'},
{'3', '2', '1'}
byte rowPins[ROWS] = {5, 6, 7, 8}; //The connection with the arduino is
byte colPins[COLS] = {2, 3, 4}; //listed here
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int redLED = 12; //The red LED is connected to pin 12
int greenLED = 13; //The green LED is connected to pin 13
setLocked(true)
pinMode(redLED, OUTPUT); //The LEDs are defined as Output
pinMode(greenLED, OUTPUT);
servoblue.attach(11); //The servo is connected to pin 11
setLocked(true);
char key = keypad.getKey();
if (key == " * " || key == " # ") If the lock is open it can be locked again by pushing "*" or "#" on the //keypad
position = 0;
setLocked(true); //The command to close the lock after „*“ or „#“ is pushed
if (key == password[position])
position ++;
if (position == 3) //This part defines how many digits our code will have.In this case we have 3 digits //(123).
setLocked(false);
delay(100)
void setLocked(int locked)
if (locked) // If the lock is closed..
digitalWrite(redLED, HIGH); //..the red LED should light up..
digitalWrite(greenLED, LOW); //..the green LED not..
servoblue.write(90); //and the servo should turn to a 90 degree position.
else //if the lock is open..
digitalWrite(redLED, LOW); //..the red LED should be off..
digitalWrite(greenLED, HIGH); //..and the green LED should light up..
servoblue.write(0); //..and the servo should turn to a 0 degree position.
And errors message:
C:\Users\Famille\Documents\Arduino\Keypad_lock\Keypad_lock.ino:8:18: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Keypad_lock:39:10: error: expected constructor, destructor, or type conversion before '(' token
setLocked(true)
Keypad_lock:41:1: error: expected declaration before '}' token
exit status 1
Hello, I need help because being a novice in programming I wanted to know what was the problem in this program and if possible if someone could correct me or tell me the changes to do. Thank you in advance !!
