My code doesn't upload to arduino lilypad.
Hi, I've recently bought an Arduino Lilypad that I'm programming with "FTDI Basic Breakout - 3.3V". I've done this before without any problem, but with this new one arduino it's not possible. Here's the output when I send the sketch in debug mode:
Binary sketch size: 920 bytes (of a 14336 byte maximum) /home/ubuntu/Desktop/arduino-0018/hardware/tools/avrdude -C/home/ubuntu/Desktop/arduino-0018/hardware/tools/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P/dev/ttyUSB0 -b19200 -D -Uflash:w:/tmp/build4700057582393089853.tmp/Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 22 2007 at 13:15:12 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "/home/ubuntu/Desktop/arduino-0018/hardware/tools/avrdude.conf" User configuration file is "/home/ubuntu/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0 Using Programmer : stk500v1 Overriding Baud Rate : 19200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding avrdude: Send: Q [51] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding
I think I could upload the Blink example for the first time, but now I don't know if the led in pin 13 is blinking because of the bootloader or because of the Blink code.
Any Idea?
Thanks
me too with a LilyPad xbee!
I got the same message trying to upload to an http://lilypadxbee.katehartman.com/about-board/ lilypad-XBee. The general advice is to tickle with the right timings of the reset switch but I tried to connect the reset (rst pin 5) to the ground but I see no change, no light on (on pin 13), and the tester showed no tension on the rst pin. What's the way to correctly reset and see the light activity on board?
I have the LilyPad 328 selected in my preference but I tried also with 168, and the FTDI USB Serial Device conv. is correctly seen as ttyUSB0
here are two (quick) pictures I took with the FTDI connected to 6 90° male strp soldered on the LilyPad XBee holes.
bear with me it's my first solder project :) thanks for any advice... maybe I've toasted it?
