My Code Doesnt Work Anymore To Output Music From SD Card Module On Arduino Mega (TMRPCM Library Doesnt Work Properly)
Hi I have a problem with my code because in my previous project my arduino mega could make a sound but after I tried again in the near future it turned out that the sound could not come out. but when I used the default arduino example program the idea for the simple tone turned out to work. does anyone have a solution? Note: "The Code Work Properly On UNO"
#include "SD.h"
#define SD_ChipSelectPin 53
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
void setup(void) {
tmrpcm.speakerPin = 8;
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
tmrpcm.setVolume(5);
Serial.println("Play Music");
tmrpcm.play("dona.wav");
Serial.println("Loop Music");
  // We'll send debugging information via the Serial monitor
void loop(void) {
What does this code outputs to the Serial Monitor?
PS Putting a two line question in the message title is not a good idea. Try to be short and clear.
the output only
Play Music
Loop Music
the music didnt came out
So your SD card initialized and works. So good!
Try to change the speakerPin to 11, it is default for Mega
i already made it on pin 11. but nothing happens
So why in the code it setup as pin 8?
i change it because i follow the guide from example code from arduino ide to play simple tone. and it works! but after i tried it on this code. nothing happens
What is your actual speaker pin ?
  • in the code
  • on connections
It must be 11 in both cases.
Showing the code that is not consistent with your actual firmware is wasting the time for those who could help you.
Right Now :
Speaker Wiring --> 8
The Code --> 8
Already Do :
Speaker Wiring --> Any PWM and Digital Pin
The Code --> Same as above
try to test
Speaker Wiring --> 11
The Code --> 11
Done
Output still same
Play Music
Loop Music
Thanks bud. The error actually on my cabble. Its broken. Thanks to help
