Hello, I was coding for a telegraph in web editor, but code doesnt work. The code is here:
int kont = 2;
int yazi[100];
pinMode(kont, INPUT);
for(int i = 0; i<101; i++){
int ba=digitalRead(kont);
if ba == 1{
delay(200);
if ba == 0{
yazi[i] = 0;
Serial.print(yazi[i]);
else{
yazi[i] = 1;
And also the terminal:
/tmp/568693805/sketch_jun10c/sketch_jun10c.ino: In function 'void loop()':
/tmp/568693805/sketch_jun10c/sketch_jun10c.ino:12:8: error: expected '(' before 'ba'
if ba == 1{
Error during build: exit status 1
I am sure with connections, but still doesnt working.
yekta_ino:
if ba == 1{
C language requires brackets () around the boolean expression in an 'if' statement.
Hi, @yekta_ino
Welcome to the forum.
What model Arduino are you using?
Can you please tell us your electronics, programming, arduino, hardware experience?
Thanks.. Tom..
like this?
if ba = 1(){
delay(9999);
I am using uno, I am not proffesional in Arduino but I had a simple education
Have you programed an Arduino before?
Thanks... Tom..
If it wasn't zero 200 milliseconds ago, its value is unlikely to have changed.
If ba equals 1 it can never equal 0 at the same time then the second comparison will never be true.
int yazi[100]; // reserves 100 addresses
for(int i=0; i<101; i++) // counts 101 numbers
xfpd
June 10, 2023, 8:42pm
12
anon57585045:
brackets ()
I respect your knowledge on all subjects, @anon57585045 , but may I sxy this:
parentheses
brackets
braces
The set of brackets, made up of subsets curly, square, and round.
xfpd
June 11, 2023, 12:52am
15
camsysca:
Ha. No.
"parenthetically" is not "round bracketly," et cetera, ibid.
Those terms are taught to those who can not remember or correctly pronounce words easily.
[edit] ... but this is not meant to point at you... it is pointed at whomever taught your teachers.
Oh, I'm fully with you, should have winked as part of the comment. That came from my nephew's school. Sigh.
system
Closed
December 8, 2023, 1:12am
17
