my code for the scouting does't work please help
hello why does my code not work
int switchstate = 0;
int switchstatea = 0;
void setup(){
// declare the LED pins as outputs
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
// declare the switch pin as an input
pinMode(12,INPUT);
pinMode(11,INPUT);
void loop(){
// read the value of the switch
// digitalRead() checks to see if there is voltage
// on the pin or not
switchstate = digitalRead(12);
switchstatea = digitalRead(11);
// if the button is not pressed
if (switchstate == LOW) { // turn of the leds
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
// this else is part of the above if() statement.
// if the switch is HIGH (the button is pressed)
// the code below will run
else {
if (switchstatea == LOW) {
digitalWrite(2, HIGH);
// wait for a half second before changing the light
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
delay(2000);
else {
you need to learn to use FOR loop
for (int i=2; i<11; i++) digitalWrite(i, LOW);
That will save a lot of typing.
and (2) use code tags ==> # button above smiley’s
you don't tell us what you expect it to do....
OK As others have said, YOU DON’T TELL US WHAT IT’S SUPPOSED TO DO.
But with a bit of reverse engineering I’ve rewritten it in a form that will be hopefully be easier to maintain (and for you to spot the error in your logic.
void setup(){
int n;
//SET PINS 2-10 AS OUTPUT
for(n=2;n<11;n++)
  {pinMode(n,OUTPUT);
   digitalWrite(n,LOW);
  pinMode(12,INPUT);
  pinMode(11,INPUT);
void loop(){
int switchstate=2*digitalRead(12)+ digitalRead(11);
//switch logic (easier to get head around active high)
switchstate=switchstate^3;
//switchstate now holds the following value
//0 neither swtich active
//1 switch on pin 11 active
//2 switch on pin 12 active
//3 both switches active;
int n;//used in loops
switch(switchstate)
   { //pin 12 active (irrespecive of pin 11s state)
     case 2: case 3:
           digitalWrite(2,LOW);
    case 1://pin 11 active
       //TURN ON OUTPUTS ONE AT A TIME
       for(n=3;n<11;n++)
         {digitalWrite(n,HIGH);
         //WAIT 2 SECONDS
         delay(2000);
         //SET ALL OUTPUTS LOW
       for(n=2;n<11;n++)
      case 0://No switches active
        digitalWrite(2,HIGH);
You’ll notice that when the loop starts to run, pins 3-10 are already low. The only case where they are set to HIGH are when you press the switch on pin 11; But this also sets them back to low again before it exits. So there is no point setting them to low for the shear hell of it.
