my code is not detecting if before else
i need help with my code because it is saying that there is no "if" before "else" please help here is the code if it helps.
define LED 12
define BUTTON 7
void setup() { { pinMode(LED, OUTPUT); pinMode(BUTTON, INPUT); }
void loop() if ( digitalRead(BUTTON)==HIGH) { digitalWrite(LED, LOW); } else { digitalWrite(LED, HIGH); } }
Arduino: 1.8.2 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/jayden/Desktop/program/program.ino: In function 'void setup()': program:11: error: expected initializer before 'if' if ( digitalRead(BUTTON)==HIGH) ^ program:15: error: 'else' without a previous 'if' else ^ exit status 1 expected initializer before 'if'
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
You seem to have lost the opening { on the loop function. Always check your braces. If you press control-T the IDE will format the code and indent the blocks and make these sort of errors very easy to see. It also makes your code much more readable.
Found the missing "{"
tinman13kup: void setup() { { pinMode(LED, OUTPUT); pinMode(BUTTON, INPUT); }
Great. It's cheaper to reuse one than to have to buy a new one.
Loop needs one too.
Code tags, please.
