my code is running but nothing is written to file
in my project i use a keypad to select different members and through xbee i generate different values and transfer from one room to other , in the second room i use xbee to receive the numbers from key pad, and i can recieve the numbers and the task assigned for numbers is occuring, but no text is printed to the file in memory card, i use rtc ds1307 for date and time and memory card module and an xbee, please help me to solve this problem ,
#include <SPI.h>
#include<SD.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
File file;
int CS_PIN=10;
   //Rx,Tx
initializeSD();
  Wire.begin();
  rtc.begin();
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(2015,6,2,9,31,0));
 createFile("stack.txt");
 int x;
DateTime now = rtc.now();
Serial.println(file);
  while (Serial.available())
    x=Serial.read();
     Serial.println(x);
  switch(x)
        case 49:
  // if the file is available, write to it:
  if (file)
    delay(2000);
    file.println("  Mrs.K.HARIPRIYA   EMBEDED SYSTEMS  ");
    // print to the serial port too:
    Serial.println("  Mrs.K.HARIPRIYA   EMBEDED SYSTEMS  ");
        case 50:
  if (file) {
     delay(2000);
    file.println(" Mrs.N.Parijatham  CONTROL SYSTEMS");
    Serial.println(" Mrs.N.Parijatham  CONTROL SYSTEMS");
        case 51:
  if (file)
     delay(2000);
    file.println("  Mr.K.Praveen      DSP  ");
    Serial.println("  Mr.K.Praveen      DSP  ");
        case 52:
  if (file)
     delay(2000);
    file.println("  Mr.TSRCH Murthy   DC  ");
    Serial.println("  Mr.TSRCH Murthy   DC  ");
        case 53:
  if (file)
     delay(2000);
     file.println("  Mr.BALA KRISHNA   OOPS  ");
    Serial.println("  Mr.BALA KRISHNA   OOPS  ");
        case 73:
  if (file)
    delay(2000);
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
     delay(2000);
     file.print(now.year(), DEC);
     file.print('/');
     file.print(now.month(), DEC);
     file.print('/');
     file.print(now.day(), DEC);
     file.print(' ');
     file.print(now.hour(), DEC);
     file.print(':');
     file.print(now.minute(), DEC);
     file.print(':');
     file.print(now.second(), DEC);
     file.println();
    case 69:
  if (file) { delay(2000);
     file.print(':');
     file.print(':');
     file.println();
void initializeSD()
  Serial.println("Initializing SD card...");
  pinMode(CS_PIN, OUTPUT);
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
int createFile(char filename[])
  file = SD.open(filename, FILE_WRITE);
  if (file)
    Serial.println("File created successfully.");
    return 1;
  } else
    Serial.println("Error while creating file.");
    return 0;
i can observe in the serial window but nothing is printed to SD card , wen i see sd card only an empty text file is created
If you use CTRL-T in the IDE the code will auto indent and will look better readable
what is this line supposed to do?
The data is not physically written to the card until there is a file.close() statement.
You need to manage your open and close file statements better. I would recommend starting each case with a
file = SD.open("stack.txt", FILE_WRITE); and ending each case with a file.close().
case 49:
          if (file)
            delay(2000);
          file.close();
Thank you , the words are printed to SD card.
