Hello Everyone,
I am doing one project on arduino smart iot agriculture with blynk IoT platform. where i am interfacing two sensor 1 nos. temperature sensor (LM35) and 2nos. moisture sensor both are analog sensor. Step one i am interface both sensor one by one programming ok working fine, but when i marge both program it running but value changes continuously. for that i define both separate function and compile, but after that same problem happen with program please guide.
code :-
#include <Servo.h>
int val;
Servo sg90;
int servo_pin = 11;
int LED = 2;
pinMode(LED, OUTPUT);
sg90.attach(servo_pin);
val = analogRead(A0);
Serial.print(val);
float mv = ( val/1024.0)5000;
float cel = mv/10;
float farh = (cel9)/5 + 32;
Serial.print("TEMPRATURE = ");
Serial.print(cel);
Serial.print(" *C");
if( cel>= 26 )
sg90.write(180); // moving the servo at 180 degrees
delay(100);
sg90.write(0); // moving the servo at 0 degree
moisture();
void moisture()
float mp;
int sensor_analog;
sensor_analog = analogRead(A1);
mp = ( 100 - ( (sensor_analog/1023.00) * 100 ) );
Serial.print("Moisture Percentage = ");
Serial.print(mp);
Serial.print("%");
if( mp <= 50 )
digitalWrite(LED, HIGH);
else{
digitalWrite(LED, LOW);
temperature_interface.ino (1.05 KB)
