The code is supposed to controll a camera slider with a stepper motor. I have the stepper motor all wired up and it works great. The speed of the stepper is set by chosing different combinations of the 4 switsches. There are 16 combinations in total. I tested all of this with just the first 3 combinations. (Mode s2, Mode s3 and Mode s4). This worked perfectly, but after adding the other 14 combinations the Serial monitor shows that it does not track the mode correctly anymore. It switches randomly the modes it is in. So it seems as if it is missreading the button combinations. This also happens on the 123Circuits, so its not hardware I think.
I guess there is something wrong with my if statements so that more than one “mode” is true at the same time. Is this the case? With modes I mean “Mode s2”, “Mode s3” and so on.
int Pin2 = 2; //Pin 1 cannot be used for this. Start at 2.
int Pin3 = 3;
int Pin4 = 4;
int Pin5 = 5;
int Pin6 = 6;
int Pin7 = 7;
int Pin8 = 8;
int Pin9 = 9;
int SliderLength = 197; //Travel length in mm
double PulleyDiameter = 6.6; //Pulley Diameter in mm
int TravelTime; //Used for calculations in the loop section.
double Steps; //Steps required to move along the entire Rail.
double StepDelay;
int StepsTaken = 0;
bool s2; ///s2 stands for switch2_status. It starts at 2 so we can match the pin.
bool s3;
bool s4;
bool s5;
bool s6;
bool s7;
const int stepPin = 8; //defines the step pin
const int dirPin = 9; //defines the direction pin
Serial.begin(9600); //Required for Serial Monitor
pinMode(Pin2, INPUT);
pinMode(Pin3, INPUT);
pinMode(Pin4, INPUT);
pinMode(Pin5, INPUT);
pinMode(Pin6, INPUT);
pinMode(Pin7, INPUT);
pinMode(Pin8, OUTPUT);
pinMode(Pin9, OUTPUT);
Steps = 200 * (SliderLength / (3.14 * PulleyDiameter)); ///Calculates the Steps required to move along the entire Rail.
Serial.println("");
Serial.print("Steps = ");
Serial.println(Steps);
digitalWrite(dirPin, HIGH); //Defines the direction of travel. LOW reverses it.
void MoveStepper()
digitalWrite(stepPin, HIGH); //This moves the stepper by 1 step.
delayMicroseconds(1000); //Depends on Motor 500-1000 is good
digitalWrite(stepPin, LOW);
StepsTaken++;
// the loop routine runs over and over again forever:
s2 = digitalRead(Pin2); ///This checks the status of the switches.
s3 = digitalRead(Pin3);
s4 = digitalRead(Pin4);
s5 = digitalRead(Pin5);
s6 = digitalRead(Pin6);
s7 = digitalRead(Pin7);
if (s2 == LOW && (s3 & s4 & s5) == HIGH) ///LOW means switch is pressed/closed/conductive.
if (StepsTaken < Steps)
{ Serial.println("Mode = s2");
TravelTime = 10; //The slider will move the distance in x seconds.
StepDelay = ((TravelTime / Steps) - 0.002) * 1000; //This calculates the delay required in ms between steps to make the journey in the desired amount of time. 0.001 Seconds are deducted because the MoveStepper Method includes 2x 500microseconds delays.
MoveStepper();
Serial.print("Stepdelay = ");
Serial.println(StepDelay);
delay (StepDelay);
// THis is in miliseconds (ms) Not MICRO!
if (s3 == LOW && (s2 & s4 & s5) == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s3");
TravelTime = 30; //The slider will move the distance in 30s
MoveStepper();
delay (StepDelay); // THis is in miliseconds (ms) Not MICRO!
if (s4 == LOW && (s2 & s3 & s5) == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s4");
TravelTime = 60; //The slider will move the distance in 30s
MoveStepper();
if (s5 == LOW && (s2 & s3 & s4) == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s5");
TravelTime = 120; //The slider will move the distance in 30s
MoveStepper();
if ((s2 & s3) == LOW && (s4 & s5) == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s2,3");
TravelTime = 300; //The slider will move the distance in 30s
MoveStepper();
It is, of course, better to spell out exactly what you are comparing.
if(s2 == LOW && s3 == HIGH && s4 == HIGH && s5 == HIGH)
Of course, that is terribly complicated. Setting 4 bits in a byte, using bitSet(), and then using a switch statement with the 16 cases is far easier to follow than a bunch of complicated if statements.
PaulS:
Of course, this requires that you put the pin numbers in an array (which you should have when you started numbering the variables) and that you define how many switches there are (using the name switchCount, or changing the for statement to use your value).
Then, you can use
switch(pinInfo)
case 0:
// No switches pressed
case 1:
// Only switch one pressed
case 2:
// Only switch two pressed
case 3:
// Switches one and two pressed
// Only 12 (or more) cases to go...
The first 4 lines read the switches, invert the read value (because LOW indicates pressed) and stores them it in the associated bits. With no switches pressed, the print statement will give 0, with all switch pressed it will give 15.
Thank you for the explanation, I will look into the switch thing for my next project. I need to finish this tonight and don´t have time to change it all.
I went ahead and changed the if statements to say exactly what they are supposed to do. It still does not work. Any if statement that contains more than 1 pressed switch does not work. Only single switches work, so I have 4 modes at the moment.
Here is the new code(minus the end because of line count):
int Pin3 = 3;
int Pin4 = 4;
int Pin5 = 5;
int Pin8 = 8;
int Pin9 = 9;
double StepDelay;
int StepsTaken = 0;
bool s3;
bool s4;
bool s5;
Serial.println("");
void MoveStepper()
StepsTaken++;
if (s2 == LOW && s3 == HIGH && s4 == HIGH && s5 == HIGH) ///LOW means switch is pressed/closed/conductive.
MoveStepper();
delay (StepDelay);
if (s3 == LOW && s2 == HIGH && s4 == HIGH && s5 == HIGH) ///LOW means switch is pressed/closed/conductive.
MoveStepper();
if (s4 == LOW && s2 == HIGH && s3 == HIGH && s5 == HIGH) ///LOW means switch is pressed/closed/conductive.
MoveStepper();
if (s5 == LOW && s2 == HIGH && s3 == HIGH && s4 == HIGH) ///LOW means switch is pressed/closed/conductive.
MoveStepper();
if (s2 = LOW && s3 == LOW && s4 == HIGH && s5 == HIGH) ///LOW means switch is pressed/closed/conductive.
MoveStepper();
if (s2 = LOW && s4 == LOW && s3 == HIGH & s5 == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s2,4");
TravelTime = 600; //The slider will move the distance in 30s
MoveStepper();
if (s2 = LOW && s5 == LOW && s3 == LOW && s4 == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s2,5");
TravelTime = 1200; //The slider will move the distance in 30s
MoveStepper();
if (s3 == LOW && s4 == LOW && s2 == HIGH && s5 == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s3,4");
TravelTime = 1800; //The slider will move the distance in 30s
MoveStepper();
if (s3 == LOW && s5 == LOW && s2 == HIGH && s4 == HIGH) ///LOW means switch is pressed/closed/conductive.
{ Serial.println("Mode = s3,5");
TravelTime = 2400; //The slider will move the distance in 30s
MoveStepper();
When two or more switches are pressed, they don't all turn on at exactly the same time. If s2, s3 and s4 are pressed, your loop might see s3 on first, then s4 also comes on and then s2.
You need to add debouncing to your code so that you see the final value and ignore the intermediate ones.
