My Code Will not Compile
if someone could tell me why this code fails to compile, I would greatly appreciate it.
const int STEP = 1;               // Step BiT FOr Motor
const int CLOCK = SCL;            // SCL Serial Clock Bit
const int DATA = SDA;             // SDA Serial Data Bit for the display
const int HOME = 5;               // Home Switch connected to digital pin 5
int DIRECTION = 1;                // DIRECTION BIT for Motor
int count = 0;                    // Generic count variable
 pinMode(STEP, OUTPUT);          // sets the digital pin as output
 pinMode(DIRECTION, OUTPUT);     // Sets the Direction as an output
 pinMode(HOME, INPUT);           // Sets the Home Pin as an Input
while(HOME == 0);{                // Step backward until we are not at home
DIRECTION = 0;                   //  Set the direction to go backward
digitalWrite(STEP, HIGH);        // Turns the Step Bit on
delay(5) ;                       // Waits for 5 milliseconds
digitalWrite( STEP, LOW);        // Turns the Step Bit off
delay(5);                       // Waits for 5 milliseconds
while(HOME == 1);{                // Step forward until we are just off home
DIRECTION = 1;                   // Set the direction to go forward
digitalWrite(STEP, HIGH);        // Turns the Step Bit on delay(100)
if (count == 0){
   DIRECTION = 1;                // Basically the same sequence as above
   digitalWrite(STEP, HIGH);     // but we will sequence this twice to ensure
   delay(5) ;                    // we clear the home position by two steps
   delay(5);
     count = count++;
   DIRECTION = 1;                // 2nd time through
   delay(5) ;
   digitalWrite( STEP, LOW);     // Next would be to update the Display
   delay(5);                     // We are Home and Ready to go
   Test();
void Test(){
 // Comment Only
Moderator edit: [code][/code] tags added. (Nick Gammon)
BCox5351@Yahoo.com
What was the error message?
If you read the forum rules, add code tags in your post and explain what the problem is (or the error messages like aarg said) "I would greatly appreciate it" too.
Well, maybe this code will compile:
  while(HOME == 0);
  while(HOME == 1);
    if (count == 0){
      delay(5);
      count = count++;
      delay(5) ;
      Test();
void Test(){
  // Comment Only
The brackets didn’t matches.
Your {}'s are all screwed up. I can't tell how you want it from looking at the code.
Functions cannot be defined within another function - but I don't think this is what you meant to do.
while(HOME == 1);{ should not have a semicolon in it.
Change the end of your code like this to fix up the { }s
      Test();
void Test(){
  // Comment Only
I always type the beginning and end bracket at the same time as I type the conditional. That way I won't forget or get mixed up about where they belong. Then I fill in the lines inside the block.
http://www.gammon.com.au/tips#trap13
