my code wont display RPM
this code is for a dc motor which has a 32 bit rotary encoder with a infra red sensor circuit which will feed back to the LCD and display the rpm my issue is that the RPM displayed on the LCD is stuck at zero.
#include <LiquidCrystal.h>
#include <SimpleTimer.h>
int i;
const byte ledPin = 13;
const byte interruptPin = 2;
volatile byte state = LOW;
// the timer object
SimpleTimer timer;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 7;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// a function to be executed periodically
int repeatMe() {
static float RPMvar = (i/32)*60;
static char RPMchar[15];
dtostrf(RPMvar,6, 3, RPMchar);
lcd.setCursor(0, 0);
lcd.print("RPM: ");
lcd.setCursor(4, 0);
lcd.print(RPMchar);
return i = 0;
pinMode(ledPin, OUTPUT);
pinMode(interruptPin, INPUT);
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
timer.setInterval(1000, repeatMe);
// configure the interrupt call-back: blink is called everytime the pin
// goes from low to high.
attachInterrupt(digitalPinToInterrupt(interruptPin), blink, RISING);
digitalWrite(ledPin, state);
timer.run();
int blink() {
state = !state;
i++;
repeatMe();
return i;
An interrupt service routine that returns a value? Where to?
Please remember to use code tags when posting code
    return i = 0;oops2
the interger "i" is to hold the value of how many times the LED (pin 13) flashes, i have fixed the return i issue does this look better?
int repeatMe() {
    static char RPMchar[6];
    lcd.print("RPM: ");
    lcd.print(RPMchar);
    i = 0;
    return i;
however the code is still not displaying RPM how would you recommend me fixing this?
Post your code.
int i;
// the timer object
SimpleTimer timer;
int repeatMe() {
    lcd.print("RPM: ");
    lcd.print(RPMchar);
    i = 0;
    return i;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  timer.run();
int blink(int i) {
  state = !state;
  i++;
  repeatMe();
  return i;
int blink(int i) {
  state = !state;
  i++;
  repeatMe();
  return i;
Please see reply #1.
You’re calling repeatMe from two places.
Why?
i will get rid of that second call is this why it is not counting?
