Hello, Below is a code that I have written. The code displays correctly on the LCD and responds correctly to the encoder but for some reason the stepper will not more in the homing function or in the loop function after selecting the speed. Can anyone spot why that would be? and i have uploaded a basic code and the stepper corresponds correctly.
#include <Wire.h>
#include <AccelStepper.h>
#include <Adafruit_seesaw.h>
#define SS_SWITCH 24
#define SS_NEOPIX 6
#define SEESAW_ADDR 0x36
// LCD setup
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Adafruit Rotary encoder setup
Adafruit_seesaw ss;
const int dirPin = 8; // Direction pin
const int stepPin = 9; // Step pin
const int enablePin = 10; // Enable pin (if your driver supports it)
const int moveUpSwitchPin = 5; // Switch input to move stepper up
const int emergencyStopSwitchPin = 6; // Emergency stop button pin with pull-up
const int homeSwitchPin = 7; // Switch input for homing pull-up
int32_t encoder_position;
int minSpeed = 500;
int maxSpeed = 5000;
int minAcceleration = 500;
int maxAcceleration = 5000;
AccelStepper stepper(1, 9, 8);
int totalCases = 0;
void displaySpeedAndAccel(int speed, int acceleration) {
lcd.clear();
lcd.print("Speed: ");
lcd.print(speed);
lcd.setCursor(0, 1);
lcd.print("Accel: ");
lcd.print(acceleration);
void lcdSetup() {
lcd.init();
lcd.backlight();
lcdSetup(); // Initialize LCD only once in the setup
if (!ss.begin(SEESAW_ADDR)) {
while (1);
pinMode(dirPin, OUTPUT);
pinMode(stepPin, OUTPUT);
//if (enablePin != -1) pinMode(enablePin, OUTPUT);
//if (enablePin != -1) digitalWrite(enablePin, HIGH);
stepper.setMaxSpeed(1500);
stepper.setAcceleration(1500);
pinMode(emergencyStopSwitchPin, INPUT_PULLUP); // Set up the emergency stop switch as pull-up
bool encoderTurnedUp = false;
void waitForSelectionButtonPress() {
while (ss.digitalRead(SS_SWITCH) == HIGH) {
// Wait for the selection button to be pressed
delay(100); // Debounce
bool speedSelectionCompleted = false; // Global variable to track if speed selection is completed
void selectSpeed() {
// Check if speed selection has already been completed
if (speedSelectionCompleted) {
return;
const int maxSpeed = 5000;
const int minSpeed = 500;
lcd.clear();
lcd.print("Select speed");
delay(2000);
encoder_position = ss.getEncoderPosition();
int buttonState = HIGH; // Assuming the button is not pressed initially
int lastButtonState = buttonState;
bool speedSelected = false;
while (!speedSelected) {
buttonState = ss.digitalRead(SS_SWITCH);
// Check if the encoder is turned
int32_t new_position = ss.getEncoderPosition();
int32_t positionChange = new_position - encoder_position;
int newSpeed = stepper.maxSpeed() - (positionChange * 250);
int newAccel = stepper.acceleration() - (positionChange * 250);
// Ensure the speed stays within the range
stepper.setMaxSpeed(constrain(newSpeed, minSpeed, maxSpeed));
// Ensure the acceleration stays within the range
stepper.setAcceleration(constrain(newAccel, minSpeed, maxSpeed));
encoder_position = new_position;
displaySpeedAndAccel(stepper.maxSpeed(), stepper.acceleration());
delay(10); // Adjust this delay if needed
if (buttonState == HIGH && lastButtonState == LOW) {
// Button was released
speedSelected = true;
// Check if the emergency stop switch is pressed
if (digitalRead(emergencyStopSwitchPin) == LOW) {
emergencyStop();
// Display "Speed selected" message
lcd.clear();
lcd.print("Speed selected");
delay(1000); // Display the message for 1 second
lcd.clear();
// Set the global variable to indicate that speed selection is completed
speedSelectionCompleted = true;
// Return to exit the function
return;
void displayHomingInstructions() {
lcd.clear();
lcd.print("Press SELECT");
lcd.print("to start homing");
//bool homingDone = false;
void initiateHomingSequence() {
displayHomingInstructions();
// Wait for the user to press the SELECT button to start homing
waitForSelectionButtonPress();
// Display "Homing..." message
lcd.clear();
lcd.print("Homing...");
// Set stepper speed and acceleration to lower values during homing
stepper.setMaxSpeed(1000); // Adjust as needed
stepper.setAcceleration(500); // Adjust as needed
// Set the direction for homing
digitalWrite(dirPin, LOW); // Adjust the direction as needed
// Move the stepper motor until the home switch is triggered or a timeout occurs
unsigned long startTime = millis();
while (!digitalRead(homeSwitchPin) && (millis() - startTime < 5000)) {
stepper.runSpeed(); // Run at a constant speed during homing
delay(10);
// Stop the motor
stepper.stop();
// Reset position to zero
stepper.setCurrentPosition(0);
// Reset speed and acceleration to desired values for normal operation
stepper.setMaxSpeed(maxSpeed);
stepper.setAcceleration(maxAcceleration);
// Display "Homing Done" message
lcd.clear();
lcd.print("Homing Done");
// Clear the LCD
lcd.clear();
void updateTotalCases() {
lcd.setCursor(0, 0);
lcd.print("Total Cases: ");
lcd.print(totalCases);
bool emergencyStopTriggered = false;
void emergencyStop() {
lcd.clear();
lcd.print("E-STOP");
lcd.print("Press ENCODER to restart");
// Wait for the encoder button to be pressed
delay(10);
// Reset the emergency stop flag
// Clear the LCD after restarting
lcd.clear();
lcd.print("Restarting...");
delay(1000); // Display "Restarting..." for 1 second
loop();
// Check if the emergency stop button is pressed at any time
if (ss.digitalRead(SS_SWITCH) == LOW && !emergencyStopTriggered) {
emergencyStopTriggered = true;
emergencyStop();
lcd.clear();
// Wait for the user to release the select button to avoid accidental double-click
while (ss.digitalRead(SS_SWITCH) == LOW) {
delay(5);
// Wait for the user to press the select button to start homing
initiateHomingSequence();
// Display "Homing Done" for 1 second
lcd.clear();
lcd.clear();
while (true) {
// Check if the emergency stop or soft stop button is pressed at any time
emergencyStop();
// Allow the user to select the speed using the button
selectSpeed();
updateTotalCases();
delay(10); // Add a small delay for stability
emergencyStop();
// Emergency stop
//stepper.stop();
//lcd.clear();
//lcd.print("Emergency Stop");
while (true) {} // Halt further execution
// Check if the move-up switch is closed
if (!digitalRead(moveUpSwitchPin)) {
// If move-up switch is not pressed, move to position 1500 and then back to 0
stepper.moveTo(1500);
stepper.runToPosition();
// Increment totalCases after reaching the target position
totalCases++; // Increment total cases
updateTotalCases();
stepper.moveTo(0);
updateTotalCases();
