My counter
hi every body
i am new in arduino stuff
i finshed my first counter with LCD with uno board
the problem is the counter run ok until 32000
and countdown by them self why???
//code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
const int pinA = 11;
int lastA = LOW;
int stateA;
const long DELAY = 100;
long lastATime = 0;
// Print a message to the LCD.
lcd.begin(16,2);
// lcd.clear();
lcd.begin(16,2);
lcd.setCursor(1,0);
lcd.print(“Mohamed Adel”);
lcd.setCursor(2,1);
lcd.print(“01062517522”);
delay(5000);
lcd.clear();
lcd.setCursor(1,0);
lcd.clear();
pinMode( pinA, INPUT );
pinMode( 13, OUTPUT );
printNumbers(0);
int a = 0;
boolean changed = false;
changed = false;
int readA = trippleRead( pinA );
if ( readA == HIGH ){
digitalWrite( 13, HIGH );
digitalWrite( 13, LOW );
if ( readA != lastA && readA == HIGH ) {
a++;
changed = true;
if (changed) printNumbers( a );
lastA = readA;
void printNumbers( int a ) {
lcd.setCursor(1,0);
lcd.print(" TOTAL : 1000");
lcd.setCursor(1,1);
lcd.print(a);
lcd.setCursor(8,1);
lcd.print(":");
lcd.setCursor(11,1);
lcd.print(a/1000);
int trippleRead( int pin ) {
int r1 = digitalRead( pin );
delay(10);
int r2 = digitalRead( pin );
delay(10);
int r3 = digitalRead( pin );
return ( r1 == HIGH && r2 == HIGH && r3 == HIGH ? HIGH : LOW );
//end code
An int data type can hold values from -32768 to 32767. An unsigned int can hold 0 to 65535. If you wish to have bigger numbers use the long data type.
http://playground.arduino.cc/Code/DatatypePractices
Please read the "how to use the forum" stickies to see how to format and post code.
thank you
but i am beginner and i don't know where i have to change
thank you for your command
int a = 0;
Now read GroundFungus post again.
thank you
really this site is so useful
So, it seems you need to learn about C++ data types.
Here ya go: Variables and types - C++ Tutorials.
sorry every body i still in the problem
the counter count until 32000 and count down can any body modified my code with a new code
thanks
int lastA = LOW;
int stateA;
long lastATime = 0;
   lcd.begin(16,2);
//  lcd.clear();
  lcd.begin(16,2);
   lcd.setCursor(1,0);
   lcd.print("Mohamed Adel");
   lcd.setCursor(2,1);
   lcd.print("01062517522");
   delay(5000);
   lcd.clear();
   lcd.setCursor(1,0);
  lcd.clear();
printNumbers(0);
int a = 0;
  changed = false;
    a++;
    changed = true;
  lastA = readA;
  lcd.setCursor(1,0);
   lcd.setCursor(1,1);
  lcd.print(a);
     lcd.setCursor(8,1);
    lcd.print(":");
      lcd.print(a/1000);
  delay(10);
  delay(10);
int a = 0;
To
unsigned long a =0;[
// and
void printNumbers( unsigned long a ) {
There, did you learn anything?
groundfungus:
int a = 0;
To
// and
no i don't learn
thank you any way it is not work at all
are you compile it before you speak by that sound "did you learn anything?"
mohamedadel:
no i don't learn
What ever groundfungus wrote wont compile, because its not a full code. He is trying to point you to the right direction by pointing some portion of the code.
You might have missed the post #5 by Paul, visit the link and understand variable types.
