My custom_spiffs.csv file doesn't show up?
Hi all.
I used note pad made file as attached and saved as custom_spiffs.csv into : ...esp32\hardware\esp32\2.0.14\tools\partitions
restarted the IDE 1.8.19
can't see it?
why?
used: LilyGo T-display s3 board.
checked the location and saw a Microsoft Excel comma separated values file? be matter?
Thanks for help.
Hi @shanren. I'm not sure I understood correctly what you mean by "can't see it". Please provide a more detailed description of what you mean in a reply on this forum topic to help us to understand it.
Make sure to include the following information:
  • What did you do?
  • What were the results you expected from doing that thing?
  • What were the results you observed that did not match your expectations?
If you encountered any errors or warnings, please provide the full and exact text of those messages.
thanks.
thanks for your participate.
I've solved the question.
Was the problem the filename was custom_spiffs.csv.txt?
