Hi 6h ago i wrote and compiled this code:
#include <ESP8266WiFi.h>
#include <WiFiUDP.h>
// wifi connection variables
const char* ssid = "Tikkhan";
const char* password = "9127119007";
int ledPin = 13; // GPIO13
boolean wifiConnected = false;
// UDP variables
unsigned int localPort = 8032;
WiFiUDP UDP;
boolean udpConnected = false;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
void setup(){
// Initialise Serial connection
WiFiServer server(80);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to WiFi network
Serial.print("\n");
Serial.print("\n");
Serial.print("Connecting to ");
Serial.print(ssid);
Serial.print("\n");
WiFi.begin(ssid, password);
Serial.print(".");
Serial.print("\n");
Serial.print("WiFi connected \n");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.print("/ + \n");
// check if the WiFi and UDP connections were successful
// if there’s data available, read a packet
int packetSize = UDP.parsePacket();
if(packetSize)
Serial.print("\n");
Serial.print("Received packet of size ");
Serial.print(packetSize);
Serial.print("\n");
Serial.print("From ");
IPAddress remote = UDP.remoteIP();
for (int i =0; i < 4; i++)
Serial.print(remote[i], DEC);
if (i < 3)
Serial.print(".");
Serial.print(", port ");
Serial.print(UDP.remotePort());
Serial.print("\n");
// read the packet into packetBufffer
UDP.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
Serial.print("Contents:");
Serial.print("\n");
int value = packetBuffer[0]*256 + packetBuffer[1];
Serial.print(value);
Serial.print("\n");
// send a reply, to the IP address and port that sent us the packet we received
UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
UDP.write(ReplyBuffer);
UDP.endPacket();
// turn LED on or off depending on value recieved
if(packetBuffer[0]=='1'){
digitalWrite(2,HIGH);
}else if(packetBuffer[0]=='2'){
digitalWrite(2,LOW);
it run correctly and after that i turned off the pc.Now i turned on the pc and wanted to compile a new code , fore example:
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
But i saw that the compile process is stop at the beginning state without any error.i opened the serial monitor and saw that it wrote : Connecting to Tikkhan !!!!!!! But i turned back from my office to my home and there is no Tikkhan WiFi! How can i reset the serial monitor and the ESP8266 Device?
I pressed and hold the rst and flash button on the device over and over but it does not reset!!!
