My EasyVR project
This is my first Arduino project. I have to say the experience has been a blast.
This program will turn lights on or off depending on the command (kitchen or livingroom). I want to set a limit for the amount of errors accumulated. As of right now when the limit is reached (3) it sets pin7 HIGH (I did this just to see if my code would work). What I want it to do when the limit is reached is to go to case GROUP_0:.
If anyone could help me out I would appreciate it.
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
  SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
#define SND_COMMANDERROR    1
//Groups and Commands
int count=0;
int pin7 = 7;
int pin8 = 8;
int pin4 = 4;
int val;
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_COMPUTER = 0,
enum Group1
  G1_KITCHEN = 0,
  G1_LIVINGROOM = 1,
EasyVRBridge bridge;
int8_t group, idx;
  pinMode(pin8, OUTPUT);
  pinMode(pin4, OUTPUT);
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(0);
  group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      count++;
      easyvr.playSound(1, EasyVR::VOL_FULL);
      Serial.print("Error ");
      Serial.println(err, HEX);
    if (count == 3)     //if 3 errors are sent do something
      digitalWrite(7, HIGH);
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_COMPUTER:
        group = GROUP_1;
    case GROUP_1:
      switch (idx)
      case G1_KITCHEN:
        group = GROUP_0;
        val = digitalRead(pin8);
        if (val == LOW)
          digitalWrite(pin8, HIGH);
           digitalWrite(pin8, LOW);
      case G1_LIVINGROOM:
        group = GROUP_0;
        val = digitalRead(pin4);
        if (val == LOW)
          digitalWrite(pin4, HIGH);
          digitalWrite(pin4, LOW);
You can't go to a case.
What you need to do is look at what causes that case to be executed. In your code, GROUP_0 is a value that group can have. When you want that case to be executed again, you need to set group to GROUP_0 and call the function containing the switch statement.
      group = GROUP_0;
      switch (idx)
        case G0_COMPUTER:
        group = GROUP_1;
Thanks alot.
This brings me to a new question though lol. If I want to "reset" the count, do i need to use an array?
For what? Resetting count is easy:
count = 0;
I tried that, I must have put it in the wrong place?
      group = GROUP_0;
      switch (idx)
        case G0_COMPUTER:
        group = GROUP_1;
        count = 0;
After 3 errors it will go back to GROUP_0. But the count is still increasing (I presume).
AH ok nm, I did put it in the wrong place. Thanks for the help I appreciate it.
Hi!!! I'm trying to test an easyvr shield, but when i open the serial monitor i have this error... EasyVR not detected! some ideas?!!? Thanks!!
nytro81:
You need to give alittle more information.. Possibly start a new thread since this thread isn't related to your problem.
