The data in EEPROM kept resetting ever since i’ve added RTC1307 and its code. Here’s my code:
#include <avr/io.h>
#include <avr/interrupt.h>
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include <Arduino.h>
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
unsigned int tvalue;
unsigned long total_tvalue;
unsigned long imp_count;
float wattpower=0.0;
unsigned int t_overflow_count;
unsigned int start;
float imp_period;
float culimp_period;
unsigned int display =0;
unsigned int timer_value;
float energy_KWH;
LiquidCrystal lcd(12,11,9,4,3,5);
const int swpin=7;
const int buttonPin=8;
int pinState=0;
int btn=0;
#define ledPin 13
int addr=0;
tmElements_t tm;
pinMode(swpin,INPUT);
pinMode(ledPin, OUTPUT);
pinMode(buttonPin,INPUT);
lcd.begin(16,2);
long four = EEPROM.read(addr);
long three = EEPROM.read(addr + 1);
long two = EEPROM.read(addr + 2);
long one = EEPROM.read(addr + 3);
//Return the recomposed long by using bitshift.
long imp_count = ((four << 0) & 0xFF) + ((three << 8 ) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
energy_KWH = (float)(imp_count * 0.0005); // cumulative kWh value
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
TCNT1=0;
TIMSK1 |= (1 << TOIE1); // enable timer interrupt
TCCR1B |= (1<<CS10);
//CLKPR |=(1<<CLKPCE);
//CLKPR |=0x00;
EIMSK |= (1 << INT0); // Enable external interrupt INT0
EICRA |= (1 << ISC01); // Trigger INT0 on falling edge
interrupts(); // enable all interrupts
while (!Serial) ; // wait for serial
delay(200);
//tmElements_t tm;
[glow=yellow,2,300]{
pinState=digitalRead(buttonPin);
if (pinState == LOW)
delay(100);
if(pinState == LOW)
for (int i = 0; i < 512; i++) // write a 0 to all 512 bytes of the EEPROM
EEPROM.write(i, 0);
lcd.setCursor(0,1);
lcd.print("E : 0.0000");
lcd.print(" kWh");
//start=0;
} [/glow]
btn=digitalRead(swpin);
switch(btn)
case LOW:
lcd.clear(); //clears LCD screen
lcd.setCursor(0,1); // set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.print("PWR : "); // prints text onto assigned cursor position
lcd.setCursor(5,1);
lcd.print(wattpower,0);
lcd.print(" W");
case HIGH:
lcd.print("E :"); // prints text onto assigned cursor position
lcd.setCursor(3,1);
lcd.print(energy_KWH,4);
lcd.print(" kWh");
break; //exit from loop
if (RTC.read(tm)) {
lcd.setCursor(0,0);
lcd.print(tm.Hour);
lcd.print(':');
lcd.print(tm.Minute);
lcd.print(':');
lcd.print(tm.Second);
//Serial.print(" ");
//Serial.print(tm.Day);
// Serial.write('/');
// Serial.print(tm.Month);
// Serial.print(tmYearToCalendar(tm.Year));
// Serial.print(" ");
if (RTC.chipPresent()) {
Serial.println("The DS1307 is stopped. Please run the SetTime");
Serial.println("example to initialize the time and begin running.");
Serial.println("DS1307 read error! Please check the circuitry.");
delay(9000);
//Serial.println(state);
delay(1000); // put your main code here, to run repeatedly:
ISR(TIMER1_OVF_vect)
t_overflow_count++;
digitalWrite(ledPin, digitalRead(ledPin) ^ 1);
int address=0;
byte four ;
byte three ;
byte two ;
byte one ;
ISR(INT0_vect) {
if (start==0)
// reset timer values, and start
// timer
tvalue=0;
TCNT1=0;
start=1;
t_overflow_count=0;
display=1;
TCCR1B = 0; //stop timer
// compute power in watts
// and convert to ascii
tvalue=TCNT1; // get residual 16-bit timer0 value
total_tvalue = (((unsigned long) t_overflow_count) << 16) + tvalue; // compute total time elapsed in bits between 2 impulses
imp_period=(float)(total_tvalue * 0.0000000625);
culimp_period = culimp_period + imp_period; // compute total time elapsed in sec; 1 bit = 6us
wattpower= (1800)/imp_period; // power = (watt-sec/impulse period)
//sprintf (watt_buf, "%9.0f", wattpower); // convert floating point value to ascii for LCD display
// compute energy in kilowatts-hour
long four = EEPROM.read(address);
long three = EEPROM.read(address + 1);
long two = EEPROM.read(address + 2);
long one = EEPROM.read(address + 3);
imp_count++;
//sprintf (KWH_buf, "%9.3f", energy_KWH); // here is sprintf prototype function usage
if(imp_count > 2000000000)
imp_count = 0;
//Decomposition from a long to 4 bytes by using bitshift.
//One = Most significant -> Four = Least significant byte
four = (imp_count & 0xFF);
three = ((imp_count >> 8 ) & 0xFF);
two = ((imp_count >> 16) & 0xFF);
one = ((imp_count >> 24) & 0xFF);
//Write the 4 bytes into the eeprom memory.
EEPROM.write(address, four);
EEPROM.write(address + 1, three);
EEPROM.write(address + 2, two);
EEPROM.write(address + 3, one);
// reset timer values, and restart
// timer
t_overflow_count=0;
tvalue=0;
TCNT1=0;
print2digits(tm.Hour);
Serial.print(':');
print2digits(tm.Minute);
Serial.print(':');
print2digits(tm.Second);
Serial.print(" ");
Serial.write('/');
Serial.write('/');
Serial.print(" ");
Serial.print(energy_KWH,4);
Serial.print("kWh, ");
Serial.print(wattpower,0);
Serial.print("W, ");
Serial.println(culimp_period);
Serial.print(" ");
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
And the serial monitor (before commenting out the clearing of EEPROM part)
00:00:00 0/0/1970 0.0010kWh, 0W, 0.00
00:00:00 0/0/1970 0.0005kWh, 1796W, 1.00
00:00:00 0/0/1970 0.0010kWh, 1814W, 1.99
09:38:54 22/7/2014 0.0015kWh, 1817W, 2.98
09:38:54 22/7/2014 0.0005kWh, 1814W, 3.98
09:38:54 22/7/2014 0.0010kWh, 1820W, 4.97
09:38:54 22/7/2014 0.0015kWh, 1820W, 5.96
09:38:57 22/7/2014 0.0020kWh, 1820W, 6.94
09:38:58 22/7/2014 0.0025kWh, 1814W, 7.94
09:38:58 22/7/2014 0.0005kWh, 1814W, 8.93
09:38:58 22/7/2014 0.0010kWh, 1814W, 9.92
09:39:02 22/7/2014 0.0015kWh, 1817W, 10.91
09:39:03 22/7/2014 0.0020kWh, 1814W, 11.90
09:39:04 22/7/2014 0.0025kWh, 1814W, 12.90
09:39:05 22/7/2014 0.0030kWh, 1814W, 13.89
09:39:06 22/7/2014 0.0035kWh, 1814W, 14.88
09:39:06 22/7/2014 0.0005kWh, 1814W, 15.87
09:39:06 22/7/2014 0.0010kWh, 1816W, 16.86
09:39:06 22/7/2014 0.0015kWh, 1814W, 17.85
09:39:09 22/7/2014 0.0020kWh, 1817W, 18.85
09:39:09 22/7/2014 0.0005kWh, 1814W, 19.84
09:39:09 22/7/2014 0.0010kWh, 1818W, 20.83
09:39:13 22/7/2014 0.0015kWh, 1815W, 21.82
09:39:13 22/7/2014 0.0020kWh, 1814W, 22.81
09:39:13 22/7/2014 0.0005kWh, 1814W, 23.80
09:39:13 22/7/2014 0.0010kWh, 1816W, 24.79
09:39:17 22/7/2014 0.0015kWh, 1820W, 25.78
09:39:18 22/7/2014 0.0020kWh, 1814W, 26.78
09:39:19 22/7/2014 0.0025kWh, 1814W, 27.77
09:39:20 22/7/2014 0.0030kWh, 1814W, 28.76
09:39:21 22/7/2014 0.0035kWh, 1814W, 29.75
09:39:22 22/7/2014 0.0040kWh, 1814W, 30.74
09:39:23 22/7/2014 0.0045kWh, 1814W, 31.74
*I can’t paste the screenshot of serial monitor, so i copied and pasted it.
But once I commented out the button for clearing EEPROM (highlighted part of code), the program works alright. But it’s a requirement to have this feature (button to clear EEPROM) for this project. What’s the problem with my code? Please help, Thanks a lot!
