MY ESP32S3 not showing in the WiFi network
Hi
I am using ESP32 S3 module
I can upload the program to the module but it does not how in the wifi network
Normally any development boards visible in the WiFi network once the power is supplied to the board but I am using ESP module as per the above image so it does not show in the wifi network
Please advise
I am new to area
If you wish to test your hardware, Adafruit has a Python test:
WiFi Test | Adafruit QT Py ESP32-S3 | Adafruit Learning System
Of course, you need to flash CircuitPython.
Hi mrburnettl , Thanks for the reply
Actually my hardware is working . I can upload the program and I connected the LED to one pin and I can write the program to blink the LED
Do I need to upload any firmware to visible the ESP in the network
Please advise
Thanks in advanced
Actually, under Arduino, core_0 is used for RF hardware and protocol stacks, etc. core_1 is used by Arduino via FreeRTOS.
These SoC have several physical hardware structures connected internal by power busses. Even the Antenna-on-board could be shorted by sloppy assembly.
I uploaded following code to the esp as per the you given link but it does not show in the wifi list
// SPDX-FileCopyrightText: 2020 Brent Rubell for Adafruit Industries
// SPDX-License-Identifier: MIT
  Web client
 This sketch connects to a website (wifitest.adafruit.com/testwifi/index.html)
 using the WiFi module.
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the Wifi.begin() call accordingly.
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 31 May 2012
 by Tom Igoe
#include <WiFi.h>
// Enter your WiFi SSID and password
char ssid[] = "YOUR_SSID";             // your network SSID (name)
char pass[] = "YOUR_SSID_PASSWORD";    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                      // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "wifitest.adafruit.com";    // name address for adafruit test
char path[]   = "/testwifi/index.html";
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to Wifi network:
  Serial.print("Attempting to connect to SSID: ");
  Serial.println(ssid);
  WiFi.begin(ssid, pass);
      Serial.print(".");
  Serial.println("");
  Serial.println("Connected to WiFi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    // Make a HTTP request:
    client.print("GET "); client.print(path); client.println(" HTTP/1.1");
    client.print("Host: "); client.println(server);
    client.println("Connection: close");
    client.println();
  // if there are incoming bytes available
  // from the server, read them and print them:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    // do nothing forevermore:
    while (true) {
      delay(100);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
So, two totally different software approaches and nothing?
I personally do not have an S3 module, so maybe someone in the forum can provide further suggestions.
If I run your program of post #5 on an ESP32-WROOM-32 (I don't have any S3 versions) I get
Attempting to connect to SSID: XXXXXX
Connected to WiFi
SSID: XXXXX
IP Address: 192.168.1.211
signal strength (RSSI):-46 dBm
connected to server
HTTP/1.1 200 OK
Server: nginx/1.18.0 (Ubuntu)
Date: Sat, 17 Dec 2022 21:18:25 GMT
Content-Type: text/html
Content-Length: 69
Last-Modified: Thu, 09 Dec 2021 17:26:22 GMT
Connection: close
ETag: "61b23c3e-45"
Accept-Ranges: bytes
This is a test of Adafruit WiFi!
If you can read this, its working :)
the ESP32-S3 supports WiFi 2.4 GHz (IEEE 802.11 b/g/n) therefore the program should work on your module assuming you have the SSID etc correct
can you upload the text (not an image) of the serial monitor output when you run the program of post #5?
Connected to WiFi
SSID: XXXXX
connected to server
HTTP/1.1 200 OK
Content-Length: 69
Connection: close
ETag: "61b23c3e-45"
[/quote][quote="horace, post:7, topic:1066578, full:true"]
Connected to WiFi
SSID: XXXXX
connected to server
HTTP/1.1 200 OK
Content-Length: 69
Connection: close
ETag: "61b23c3e-45"
[/quote]
Hi Thanks for input
This is the serial monitor output and it shows successfully connected to the wifi netwark
My concern is in my wifi network does not show my esp ssid
This is the board that I selected
image[quote="horace, post:7, topic:1066578, full:true"]
if you access your router attached devices list you should see the IP address ESP32 listed, e.g. IP 192.168.1.112
Dear Thanks for reply
Actually I should not need to access the router
What I need is......When the ESP power up it should found in the WiFi search list in the PC
Please advise
sounds like you wish to create an Access point using the ESP32 where it has own SSID and password and WiFi devices can connect too it
try a web search for ESP32 Access point, e.g. esp32-access-point-ap-web-server
First of all sorry what I can't explain the my issue
Please let me explain it again
Just I want to ...When the esp module power up.... its SSID should visible following search list
Shall we suppose we perchase esp8266 from the shop then once we connect to the phone charger ( Power supply ) Then the esp module will found the wifi serach list in the phone or PC )
8a97241535c46cc2c6d9f3be063569d014d1f616_2_310x499
usually when you get a new ESP device you need to load a program to give you the functionality you require, e.g. using the code from how-to-turn-esp32-into-access-point
creates an Access point called ESP32ap when appears in the WiFi list on my smartphone which I can connect too using the password "12345678"
Dear I uploaded following code to the board . Now it visibles on the WiFi list
#include <WiFi.h>
const char *ssid = "ESP32";
const char *pass = "PASSWORD";
  Serial.println("Configure access piont");
  WiFi.softAP(ssid, pass);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP-IP Address");
  Serial.println(myIP);
Then I uploaded following code which is from WiFiManager (Basic) code then the board dissipate in the Wifi list
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
    // WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
    // it is a good practice to make sure your code sets wifi mode how you want it.
    //WiFiManager, Local intialization. Once its business is done, there is no need to keep it around
    WiFiManager wm;
    // reset settings - wipe stored credentials for testing
    // these are stored by the esp library
    // wm.resetSettings();
    // Automatically connect using saved credentials,
    // if connection fails, it starts an access point with the specified name ( "AutoConnectAP"),
    // if empty will auto generate SSID, if password is blank it will be anonymous AP (wm.autoConnect())
    // then goes into a blocking loop awaiting configuration and will return success result
    bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
    // res = wm.autoConnect("AutoConnectAP"); // anonymous ap
    res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        Serial.println("Failed to connect");
        // ESP.restart();
    else {
        //if you get here you have connected to the WiFi
        Serial.println("connected...yeey :)");
Please advise
