Sorry to disturb everyone. I'm using the AS608 fingerprint sensor with the arduino uno R3 board to insert the fingerprint into the database by using php. The library that I use is Adafruit Fingerprint Sensor Library. What I want to do is I want to use my fingerprint sensor to save the fingerprint into database instead of just store in the fingerprint sensor. But the problem is it always shows connection failed and the fingerprint isn't insert into the database. Can someone help me regarding this problem? Thanks.
Here is the source code for my arduino.
#include <Adafruit_Fingerprint.h>
#include <SPI.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177); //IP address for your arduino.
char server[] = "192.168.1.106"; //IP address of your computer.
int interrupt=0; //Variable to control the iterations of void loop().
String mod=""; //Variable to be written on the database.
String rcv=""; //Variable in which the server response is recorded.
EthernetClient client;
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
// set the data rate for the sensor serial port
finger.begin(57600);
Ethernet.begin(mac, ip);
delay(5000); //Wait for ethernet to connect.
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
void httpRequest()
{// Connect to the server (your computer or web page)
if (client.connect(server, 80)) {
client.print("GET /fingerprint/fingerprint.php?"); // This
client.print("ID_S="); // This
client.print(id); // And this is what we did in the testing section above. We are making a
GET request just like we would from our browser but now with live data from the sensor
client.println(" HTTP/1.1"); // Part of the GET request
client.println("Host: 192.168.1.106"); // IMPORTANT: If you are using XAMPP you will have to find out the IP address of your computer and put it here (it is explained in previous article). If you have a web page, enter its address (ie.Host: "www.yourwebpage.com")
client.println("Connection: close"); // Part of the GET request telling the server that we are over transmitting the message
client.println(); // Empty line
client.stop(); // Closing connection to server
else {
// If Arduino can't connect to the server (your computer or web page)
Serial.println("--> connection failed\n");
uint8_t readnumber(void) {
uint8_t num = 0;
while (num == 0) {
while (! Serial.available());
num = Serial.parseInt();
return num;
void loop() // run over and over again
Serial.println("Ready to enroll a fingerprint!");
Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
id = readnumber();
if (id == 0) {// ID #0 not allowed, try again!
return;
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);;
httpRequest();
Serial.println ("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
delay(10000);
Here is my php code.
<?php
include ('connection.php');
if (isset($_GET['ID_S'])) {
$sql_insert = "INSERT INTO student (ID_S) VALUES ('".$_GET["ID_S"]."')";
if(mysqli_query($con,$sql_insert))
echo "Done";
mysqli_close($con);
echo "error is ".mysqli_error($con );
else{
echo "failed";
Here is the error that show in arduino and the error that show for my webpage.
Can someone tell me what is my problem because this is my 1st time to do the arduino, thanks.
