I just gave it my first shot to get something arduinie alive. The outcome was ok however I am still stuck with no doubt some beginners issues.
Well first arduino I tried failed, the L1 led blinks but it does not like an upload, so tried another one this worked. I upped the info from the site http://blog.lvivier.info/
Which is an application to cobine and arduino with a conrad dcf77 clock, to output Meinberg compliant data for NTP. So adding the sketch and waiting until the rig was in sync produced the result I wanted to have. I could sync a server with a dcf77 clock. Next would be to build this into a box and make it permanently connected to the server. But as I had a stck of arduino shields around I wanted to tweak this setup which I guess for a beginner might be to much..... So I added an ethernetshield IE Shield 1.1, also a serial LCD to complete it.
Next after stacking my shields tested it again, to have it working as it did before. To bad the USB connection got lost. First I blamed the USB power, but I found out hooking up the Ethernet shield is enough to break it.
My question is what's up with the ethernet shield, do I need to configure an code it before I can plug these in ( when I am not suing it yet) ? because I am aware my knowledge is currently limited so I wanted to build the NTP server and for now use USB to link it, in future I want to make an NTP server out of this generating time signals for ethernet which can sync the entire network. I would of course besides the answer to my question also welcome any info that might help to get this idea realized.
Thx.
