My First Arduino Robot, A Photovore
Arduino Uno, L298N Motor Shield, 2 Photo Resistors, Push Button, Two Small DC Motor (Out of a broken helicopter not sure of the voltage or draw, but pretty small).
const int pwm_a = 3;  //PWM control for motor outputs 1 and 2 is on digital pin 3 (or 5,6)
const int pwm_b = 11;  //PWM control for motor outputs 3 and 4 is on digital pin 9 (or 10,11)
const int dir_a = 12;  //direction control for motor outputs 1 and 2 is on digital pin 2 (or 4,7)
const int dir_b = 13;  //direction control for motor outputs 3 and 4 is on digital pin 8 (or 12,13)
const int button = 7; //Motor ON OFF button
const int righteye = 0; // Right Photoresistor on PIN 0
const int lefteye = 1; // Left Photo Resistor on PIN 1
int lVal = 0; // used to store value from right eye
int rVal = 0; // used to store value from right eye
int val = 0; // val used to store button state
int old_val = 0; //stores the old value
int state = 0; // 0= LED OFF while 1 = LED ON
  pinMode(pwm_a, OUTPUT);  //Set control pins to be outputs
  pinMode(pwm_b, OUTPUT);
  pinMode(dir_a, OUTPUT);
  pinMode(dir_b, OUTPUT);
  pinMode(button, INPUT); // button is an input
  val = digitalRead(button); // read input value and store it
  //check if there was a transition
  if ((val == HIGH) && (old_val == LOW)){
  state = 1 - state;
  old_val = val; // val is now old, store it
  // check if button is pressed (HIGH)
  // and chage the state
  if (state == 1) {
  rVal = analogRead(righteye); // Read value from right eye sensor
  lVal = analogRead(lefteye); // Read value from left eye sensor
  analogWrite(pwm_a, rVal/4);  //set both motors to run at one quarter of light level
  analogWrite(pwm_b, lVal/4);
    analogWrite(pwm_a, 0);  //set both motors to OFF
    analogWrite(pwm_b, 0);
no body yet
Ummm, and you're posting because?
Rob
To get some feedback on the code, start a thread for the project. I'm still waiting for the wheels tracks and gearbox. First project with Arduino that's all.
At a glance your code looks OK, I gather it's supposed to follow a light?
There's no debouncing on the button but that may not worry you.
The motor speed is directly tied to the light level (rVal/4), that may or may not be appropriate when you get real hardware.
You are not using the dir pins.
Rob
I'm looking at the http://www.robotshop.com/productinfo.aspx?pc=RB-Tam-27&lang=en-US Tamiya Tracked Vehicle Chassis Kit with the http://www.robotshop.com/productinfo.aspx?pc=RB-Tam-32&lang=en-US Tamiya 4-Speed Double Gear Box (Left / Right Independent) with two 3 volt motors. Do you think this is a decently good way to go about it?
Sorry I don't know enough about robots to advise on chassis etc, there may be others here who do or alternatively go over to the SoR forum.
Rob
Thanks Rob, I appreciate the input. The only qualm I was having with button debouncing was that I cant have a delay using this method of motor control.
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;           // interval at which to blink (milliseconds)
  Serial.begin(9600);  // open the serial port
    state = 1 - state;
  if (state == 1) {
  else {
    analogWrite(pwm_a, 0);  //set both motors to run at one quarter of light level
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    Serial.println(rVal);
    Serial.println(lVal);
I suppose I could use a similar routine as I use there for the serial output to have the button debouncing on a delay of 100. Would that work?
You can debounce without using delay() but I'd see if you need to first.
Rob
Here is the body of the robot itself
Now I have to add a larger platform above the reads for the core and more sensors, such as IR on the corners.
That looks like it will be a fun thing to work with.
Rob
What is the body? Some kind of off-the-shelf module?? How much and where could I get one? Looks just the thing I've been looking for?
bytedisorder:
He is using the parts quoted above or you can piece together your own with the different tamiya products.
http://www.robotshop.com/search/search.aspx?locale=en_us&keywords=tamiya&Brand=Tamiya&Category=Robot+Parts
Our you can check out stuff like http://www.robotshop.com/dfrobotshop-rover-tracked-robot-basic-kit-5.html or http://www.solarbotics.com/product/60125/
I have the dfrobotshop rover myself but they can be a bit limited if you want to do certain things.
I think there are few other platforms that take the tamiya tracks if you dig around.
