Actually, it's a Freeduino based off the Arduino, but it's essentially the same and it works with the Arduino drivers and dev program. Now that I got that over with...
Anyways, I have finished my first program. It's the flash sketch, but I made some very simple modifications; it will only flash 5 times, and it uses Serial to print to the computer that it has flashed 5 times. The LED I used is a flashing LED, so it flashes for a second instead of staying solid. I have a good knowledge of Java and C programming, and I thought I should give this a try to learn more things about the electronics side.
Check it out; I hope to do more stuff whenever I get the time.
#define ledPin 13 // LED connected to digital pin 13
#define FLASHES 5 // How many times the LED will flash
Serial.begin(9600); // Sets the baud rate to send serial data to my computer
pinMode(ledPin, OUTPUT); // sets the digital pin as output
int i;
for (i = 0; i < FLASHES; i++)
digitalWrite(ledPin, HIGH); // sets the LED on
delay(1000); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
Serial.println(i+1,DEC); // print the amount of times it has flashed so far
//Print a sentence stating how many times it has flashed
Serial.print("I am done flashing ");
Serial.print(FLASHES,DEC);
Serial.print(" times.");
I'm not using the loop function below because I only want the program to run the code once :(
void loop(){}
Edit: After posting this, I later found a red LED and it worked like it should
