My First attempt at a sketch
Its a collaboration i put together to make a Lcd xmas card
while trying to figure out more coding.
i like to learn threw trial and error.
ill post a vid tonight when i get home.
//LCD Christmas Card
//Made using Tone Library, And SerLCD Library.
//Uses Serial Lcd on Pin 1, And small Speaker on pin 12.
#include <Tone.h>
Tone tone1;
#define OCTAVE_OFFSET 0
int notes[] = { 0,
NOTE_C4, NOTE_CS4, NOTE_D4, NOTE_DS4, NOTE_E4, NOTE_F4, NOTE_FS4, NOTE_G4, NOTE_GS4, NOTE_A4, NOTE_AS4, NOTE_B4,
NOTE_C5, NOTE_CS5, NOTE_D5, NOTE_DS5, NOTE_E5, NOTE_F5, NOTE_FS5, NOTE_G5, NOTE_GS5, NOTE_A5, NOTE_AS5, NOTE_B5,
NOTE_C6, NOTE_CS6, NOTE_D6, NOTE_DS6, NOTE_E6, NOTE_F6, NOTE_FS6, NOTE_G6, NOTE_GS6, NOTE_A6, NOTE_AS6, NOTE_B6,
NOTE_C7, NOTE_CS7, NOTE_D7, NOTE_DS7, NOTE_E7, NOTE_F7, NOTE_FS7, NOTE_G7, NOTE_GS7, NOTE_A7, NOTE_AS7, NOTE_B7};
char *song = "WeWishYou:d=4,o=5,b=200:d,g,8g,8a,8g,8f#,e,e,e,a,8a,8b,8a,8g,f#,d,d,b,8b,8c6,8b,8a,g,e,d,e,a,f#,2g,d,g,8g,8a,8g,8f#,e,e,e,a,8a,8b,8a,8g,f#,d,d,b,8b,8c6,8b,8a,g,e,d,e,a,f#,1g,d,g,g,g,2f#,f#,g,f#,e,2d,a,b,8a,8a,8g,8g,d6,d,d,e,a,f#,2g,d,g,8g,8a,8g,8f#,e,e,e,a,8a,8b,8a,8g,f#,d,d,b,8b,8c6,8b,8a,g,e,d,e,a,f#,2g";
void setup(void)
  tone1.begin(12);
  StartupMessage();
void StartupMessage()
  clearLCD();
  selectLineOne();
  Serial.print(" Money Is Short");
  selectLineTwo();
  Serial.print("And Times R Hard");
  delay(2000);
  clearLCD();
  selectLineOne();
  Serial.print("So Heres Ur Gift");
  selectLineTwo();
  Serial.print("A Christmas Card");
  delay(2000);
  clearLCD();
  selectLineOne();
  Serial.print("  Yours Truely");
  selectLineTwo();
  Serial.print("    Sam");
  delay(2000);
  clearLCD();
  delay(2000);
  selectLineOne();
  Serial.print("     Merry");
  selectLineTwo();
  Serial.print("   Christmas!");
void selectLineOne(){
  Serial.print(0xFE, BYTE);
  Serial.print(128, BYTE);
void selectLineTwo(){
  Serial.print(192, BYTE);
void goTo(int position) {
if (position<16){ Serial.print(0xFE, BYTE);
  Serial.print((position+128), BYTE);
}else if (position<32){Serial.print(0xFE, BYTE);
  Serial.print((position+48+128), BYTE);
} else { goTo(0); }
void clearLCD(){
  Serial.print(0x01, BYTE);
void backlightOn(){
  Serial.print(0x7C, BYTE);
  Serial.print(157, BYTE);
void backlightOff(){
void serCommand(){
#define isdigit(n) (n >= '0' && n <= '9')
void play_rtttl(char *p)
  byte default_dur = 4;
  byte default_oct = 6;
  int bpm = 63;
  int num;
  long wholenote;
  long duration;
  byte note;
  byte scale;
  while(*p != ':') p++;
  p++;
  if(*p == 'd')
  p++; p++;
  num = 0;
  while(isdigit(*p))
  num = (num * 10) + (*p++ - '0');
  if(num > 0) default_dur = num;
  p++;
  if(*p == 'o')
  p++; p++;
  num = *p++ - '0';
  if(num >= 3 && num <=7) default_oct = num;
  p++;
  if(*p == 'b')
  p++; p++;
  num = 0;
  while(isdigit(*p))
  bpm = num;
  p++;
  wholenote = (60 * 1000L / bpm) * 4;
  while(*p)
  num = 0;
  while(isdigit(*p))
  if(num) duration = wholenote / num;
  else duration = wholenote / default_dur;
  note = 0;
  switch(*p)
  case 'c':
  note = 1;
  case 'd':
  note = 3;
  case 'e':
  note = 5;
  case 'f':
  note = 6;
  case 'g':
  note = 8;
  case 'a':
  note = 10;
  case 'b':
  note = 12;
  case 'p':
  default:
  note = 0;
  p++;
  if(*p == '#')
  note++;
  p++;
  if(*p == '.')
  duration += duration/2;
  p++;
  if(isdigit(*p))
  scale = *p - '0';
  p++;
  scale = default_oct;
  scale += OCTAVE_OFFSET;
  if(*p == ',')
  p++;
  if(note)
  tone1.play(notes[(scale - 4) * 12 + note]);
  delay(duration);
  tone1.stop();
  delay(duration);
void loop(void)
  play_rtttl(song);
  while(1);
