my first binary clock not working
Excellent!
Does this also work?
#define SIZEOF_ARRAY(ARRAY)             (sizeof(ARRAY) / sizeof(ARRAY[0]))
// CONSTANTS
const uint8_t   pinBUTTON_LIGHTS        = 0;        // SYNONYM ENHANCES READABILITY
const uint8_t   pinBUTTON_MINUTES       = 19;       // SYNONYM ENHANCES READABILITY
const uint8_t   pinBUTTON_HOURS         = 14;       // SYNONYM ENHANCES READABILITY
const uint8_t   LED_OFF                 = LOW;      // SYNONYM ENHANCES READABILITY
const uint8_t   LED_ON                  = HIGH;     // SYNONYM ENHANCES READABILITY
const uint8_t   BUTTON_UP               = LOW;      // SYNONYM ENHANCES READABILITY
const uint8_t   BUTTON_DOWN             = HIGH;     // SYNONYM ENHANCES READABILITY
const uint8_t   pinsLED[]               = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 };
const uint8_t   pinsMinutesOnesLEDS[]   = { 1, 2, 3, 4 };
const uint8_t   pinsMinutesTensLEDS[]   = { 5, 6, 7 };
const uint8_t   pinsHoursOnesLEDS[]     = { 8, 9, 10, 11 };
const uint8_t   pinsHoursTensLEDS[]     = { 12, 13 };
int     second;                                     // GLOBAL ZERO'D BY COMPILER <-uint8_t to int
int     minute;                                     // GLOBAL ZERO'D BY COMPILER <-uint8_t to int
int     hour;                                       // GLOBAL ZERO'D BY COMPILER <-uint8_t to int
void setDigits(uint8_t digit, const uint8_t pinsLED[], uint8_t lengthArray)
    for ( int i = lengthArray; i--; )
        digitalWrite(pinsLED[i], ((digit & (1 << i)) ? LED_ON : LED_OFF));
    // static variables are initialized once and keep their values between function calls
    // set up a local variable to hold the last time we moved forward one second
    static unsigned long lastTick = 0UL;
    if ( (millis() - lastTick) >= 1000UL )
        lastTick = millis();
        if ( 0 == (second = ((++second) % 60)) )
            if ( 0 == (minute = ((++minute) % 60)) )
                hour = ((++hour) % 24);
    if ( BUTTON_DOWN == digitalRead(pinBUTTON_LIGHTS) )
        for ( int i = SIZEOF_ARRAY(pinsLED); i--; )
            digitalWrite(pinsLED[i], LED_OFF);
        setDigits((minute / 10), pinsMinutesOnesLEDS, SIZEOF_ARRAY(pinsMinutesOnesLEDS));   // minutes ones
        setDigits((minute % 10), pinsMinutesTensLEDS, SIZEOF_ARRAY(pinsMinutesTensLEDS));   // minutes tens
        setDigits((hour   / 10), pinsHoursOnesLEDS,   SIZEOF_ARRAY(pinsHoursOnesLEDS));     // hours ones
        setDigits((hour   % 10), pinsHoursTensLEDS,   SIZEOF_ARRAY(pinsHoursTensLEDS));     // hours tens
    if ( BUTTON_DOWN == digitalRead(pinBUTTON_MINUTES) )
        minute++;
        second  = 0;
        delay(250);
    if ( BUTTON_DOWN == digitalRead(pinBUTTON_HOURS) )
        hour++;
        second  = 0;
        delay(250);
    pinMode(pinBUTTON_MINUTES, INPUT);
    pinMode(pinBUTTON_HOURS, INPUT);
        pinMode(pinsLED[i], OUTPUT);
EDIT: Changed data type of 'second', 'minute' and 'hour'
