right so this is my first attempt at writeing arduno code
its for a jokey speed camera for RC cars
its not actually a “speed camera” its just a laser trip wire and the object has to pass through the beam in a quick enough time
i would really really apreceate if people could take a quick look and see if iv done stuff im not alowed to do or theres a line missing or anything really! iv enjoyed this and it was easier than i thought. looking forward to meny projects!
#define flash 10 //pin to flash camera
#define laser 9 //pin for laser beam
#define led 8 //pin for status led
#define button 7 //pin for button
#define led2 //pin for car seen led
int val = 0;
int button1 = 0:
int light = 0;
int dark = 0;
int split = 0;
int trigger = 0;
unsigned long fronttime = 0;
float speedmph = 0;
int carsize = 0;
float speedmps = 0;
int carpasstime = 0;
int counter = 0;
pinmode(flash, output);
pinmode(laser, output);
pinmode(led, output);
pinmode(led2, output);
pinmode(button, input);
void calabrate(){
digitalwrite(laser, high); //turn on laser
delay 300; //user alighns mirror
button1 = digitalread(button); // waits until button is pressed
while (button1 = 0) {
digitalwrite(led, high); //flashes the led while waiting
delay(200);
digitalwrite(led, low);
delay(200);
light = analogread(0); //set the LDR value for light
digitalwrite(laser, low); //turn laser off
delay(400); //let laser run down and LDR desaturate
dark = analogread(0); //set the LDR value for dark
split = (dark - light); //calculate diffrence
trigger= ((split / 2 ) + light); //calculates trigger point which is 1/3 abouve the difrence between light and dark
speedmph = 15; //enter camera trigger speed here <-----
carsize = 440; // enter car size in mm here <--------
speedmps = (speedmph * 0.44704); //comvert MPH to millimeters per millisecond (or meters per second)
carpasstime = (carsize / speedmps); //find the time it takes for a car off carsize lenght to pass at speedmph speed
digitalwrite(led, high); //turn led on
digitalwire(laser, high); //turn laser on
void loop(){
val = analogread(0); //read the LDR
if (val > trigger) { //if the ldr has no light then do the follwing:
fronttime = millis(); //record the time the beam was broken
digitalwrite(led2, high); //turn the car sense led on
while (val > trigger){
delay(5); //wait for light to retun
digitalwrite(led2, low) //turn led back off
if ((millis() - fronttime) < carpasstime) { //was the car going fast enough?
digitalwrite(flash, high) ; //turn the flash on
delay() 1000 //give it a second to go off properly
digitalwrite(flash, low) ; // turn it back off
digitalwrite(led, low) ; //turn off led
digitalwrite(laser, low); //turn laser off in sleep mode
counter = 0 //reset counter
while (counter < 60) && (button1 == 0){ //is the button pressed or is the counter past the alloted time?
delay(700);
delay(700);
digitalwrite(led, low); //read button to see if its been pressed
counter++; //add one to counter
delay(5)
If you get stuck post the code and the errors. I have had mucho experience decoding the cryptic IDE error messages as I am a beginner in Arduino C as well. : )
#define led2 6 //pin for car seen led
int val = 0;
int button1 = 0;
int light = 0;
int dark = 0;
int split = 0;
int trigger = 0;
float speedmph = 0;
int carsize = 0;
float speedmps = 0;
int counter = 0;
pinMode(flash, OUTPUT);
pinMode(laser,OUTPUT);
pinMode(led,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(button,INPUT);
void calabrate(){
digitalWrite(laser,HIGH); //turn on laser
delay(300); //user alighns mirror
button1 = digitalRead(button); // waits until button is pressed
digitalWrite(led,HIGH); //flashes the led while waiting
delay(200);
digitalWrite(led,LOW);
delay(200);
light = analogRead(0); //set the LDR value for light
digitalWrite(laser,LOW); //turn laser off
dark = analogRead(0); //set the LDR value for dark
trigger = ((split / 2 ) + light); //calculates trigger point which is 1/3 abouve the difrence between light and dark
digitalWrite(led, HIGH); //turn led on
digitalWrite(laser, HIGH); //turn laser on
void loop(){
val = analogRead(0); //read the LDR
digitalWrite(led2,HIGH); //turn the car sense led on
digitalWrite(led2, LOW); //turn led back off
digitalWrite(flash, HIGH); //turn the flash on
delay(1000); //give it a second to go off properly
digitalWrite(flash, LOW); // turn it back off
digitalWrite(led, LOW); //turn off led
digitalWrite(laser, LOW); //turn laser off in sleep mode
counter = 0; //reset counter
while (counter < 60 && button1 == 0){ //is the button pressed or is the counter past the alloted time?
delay(700);
delay(700);
digitalWrite(led, LOW); //read button to see if its been pressed
delay(5);
id perticualy like to know if one bit iv done is acceptable
iv got void setup()
then void calabration()
then void loop()
im thinking it run through the setup. then calibrate and then go round and round the loop?
// FILE: Speed_cam
// AUTHOR: Josh Sams
// VERSION: 0.1.00
// PURPOSE: RC Speed camera using laser trip wire
// DATE:11/10/13
// COPYRIGHT: Released to the public domain (not for profit)
#define FLASH 10 //pin to FLASH camera
#define LASER 9 //pin for LASER beam
#define LED 8 //pin for status LED
#define LED2 6 //pin for car seen LED
int val = 0;
int button1 = 0;
int light = 0;
int dark = 0;
int split = 0;
int trigger = 0;
float speedmph = 0;
int carsize = 0;
float speedmps = 0;
int counter = 0;
pinMode(FLASH, OUTPUT);
pinMode(LASER,OUTPUT);
pinMode(LED,OUTPUT);
pinMode(LED2,OUTPUT);
void calabrate(){
digitalWrite(LASER,HIGH); //turn on LASER
digitalWrite(LED,HIGH); //FLASHes the LED while waiting
delay(200);
digitalWrite(LED,LOW);
delay(200);
digitalWrite(LASER,LOW); //turn LASER off
delay(400); //let LASER run down and LDR desaturate
digitalWrite(LED, HIGH); //turn LED on
digitalWrite(LASER, HIGH); //turn LASER on
void loop(){
digitalWrite(LED2,HIGH); //turn the car sense LED on
digitalWrite(LED2, LOW); //turn LED back off
digitalWrite(FLASH, HIGH); //turn the FLASH on
digitalWrite(FLASH, LOW); // turn it back off
digitalWrite(LED, LOW); //turn off LED
digitalWrite(LASER, LOW); //turn LASER off in sleep mode
delay(700);
delay(700);
digitalWrite(LED, LOW); //read button to see if its been pressed
delay(5);
Once the code has been compiled there is a process that runs that calls setup() once and the repeatedly calls loop() to achieve the looping effect. Other functions will only be called if they are called by your code in of setup() or loop(), so the order in which they appear does not generally matter.
should be
while (button1 == 0) { // or LOW ?
digitalWrite(LED, LOW); // read button to see if its been pressed
in case of a mismatch between code and comment code always wins. Do not use comments if not 100% needed.
calabrate() is never called… Moving code in a function implies you need to call it from another function
setup() makes the most sense in this case
Several typos in the comments,
The structure of your code still contains sudden empty lines,
I did a redo of the style (not the logic of the code) took 3 minutes
// FILE: Speed_cam
// VERSION: 0.1.00
// DATE:11/10/13
#define FLASH 10 // pin to FLASH camera
#define LASER 9 // pin for LASER beam
#define LED 8 // pin for status LED
#define button 7 // pin for button
#define LED2 6 // pin for car seen LED
int val = 0;
int button1 = 0;
int light = 0;
int dark = 0;
int split = 0;
int trigger = 0;
float speedmph = 0;
int carsize = 0;
float speedmps = 0;
int counter = 0;
pinMode(LASER, OUTPUT);
pinMode(LED, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(button, INPUT);
void calabrate()
digitalWrite(LASER, HIGH); // turn on LASER
delay(300); // user alighns mirror
digitalWrite(LED, HIGH); // FLASHes the LED while waiting
delay(200);
delay(200);
light = analogRead(0); // read the LDR value for light
digitalWrite(LASER, LOW); // turn LASER off
delay(400); // let LASER run down and LDR desaturate
dark = analogRead(0); // read the LDR value for dark
split = (dark - light); // calculate difference
trigger = ((split / 2 ) + light); // calculates trigger point which is 1/3 abouve the difrence between light and dark
speedmph = 15; // enter camera trigger speed here <-----
speedmps = (speedmph * 0.44704); // convert MPH to meters per second
carpasstime = (carsize / speedmps); // find the time it takes for a car off carsize lenght to pass at speedmph speed
digitalWrite(LED, HIGH); // turn LED on
digitalWrite(LASER, HIGH); // turn LASER on
val = analogRead(0); // read the LDR
if (val > trigger) // if the ldr has no light then do the following:
fronttime = millis(); // record the time the beam was broken
digitalWrite(LED2, HIGH); // turn the car sense LED on
delay(5); // wait for light to retun
digitalWrite(LED2, LOW); // turn LED back off
if ((millis() - fronttime) < carpasstime) // was the car going fast enough?
digitalWrite(FLASH, HIGH); // turn the FLASH on
delay(1000); // give it a second to go off properly
digitalWrite(LED, LOW); // turn off LED
digitalWrite(LASER, LOW); // turn LASER off in sleep mode
counter = 0; // reset counter
while (counter < 60 && button1 == 0){ // is the button pressed or is the counter past the alloted time?
delay(700);
delay(700);
counter++; // add one to counter
delay(5);
// -- END OF FILE --
i think iv spotted all 7 errors
the typos arent too important to me. im dyslexic so i don’t even notice them. my brain just reads what i think it says ect
iv been leaning from the “getting started with ardunio” book and it thought me to all-ways write comments so i have been doings so
cheers for your help! have to start building it now!
// FILE: Speed_cam
// VERSION: 0.1.00
// DATE:11/10/13
#define BUTTON 7 //pin for BUTTON
int val = 0;
int BUTTON1 = 0;
int light = 0;
int dark = 0;
int split = 0;
int trigger = 0;
float speedmph = 0;
int carsize = 0;
float speedmps = 0;
int counter = 0;
pinMode(BUTTON, INPUT);
digitalWrite(LASER, HIGH); //turn on LASER
BUTTON1 = digitalRead(BUTTON); // waits until BUTTON is pressed
while (BUTTON1 == 0)
delay(200);
delay(200);
if (val > trigger) //if the ldr has no light then do the follwing:
digitalWrite(LED2, HIGH); //turn the car sense LED on
if ((millis() - fronttime) < carpasstime) //was the car going fast enough?
digitalWrite(FLASH, LOW); //turn it back off
while (counter < 60 && BUTTON1 == 0) //is the BUTTON pressed or is the counter past the alloted time?
delay(700);
delay(700);
BUTTON1 = digitalRead(BUTTON); //read BUTTON to see if its been pressed
delay(5);
//END OF FILE
By convention, all capital letter names are reserved for constants. Constants do not belong on the left of an equal sign.
Variable names should make it obvious what they help. Names like buttonState and buttonPin are much more obvious than BUTTON1 and BUTTON.
The digitalRead() function returns HIGH or LOW. You would do well to use these names, rather than 0 or 1.
For that code to do anything, the user would have to be holding the switch down when the Arduino is reset. Is that a valid thing to require?
You absolutely do not want to be sitting around with your thumb up your ass for ANY amount of time. You need to INSTANTLY recognize when the transition occurs.
this was a mistake. i used find and replace and it change all the buttons to BUTTONS. this obv changed all off them! but i let it slide
PaulS:
ok, noted
PaulS:
the laser is supposed to turn on to allow it to be set up by the user. ie position the mirror. they have to press the button after this to confirm its been done and then the code runs the calabration and the rest ect
dose that sound like its going to work?
PaulS:
delay(5);
Again, why?
fair enough
i just thought every 5 ms would be accurate enough
for some reason iv got a feeling that the chip will just go flat out and rag itself to death at the expense of unnecessary accuracy
shall i just remove it?
PaulS:
What? That comment makes no sense.
the flash is high power so its going to be run via relay. i want the relay to energize and close properly and then allow for the full flash. i dont want the relay bouncing back after a fraction off a second. 1000ms is probably slightly to long though
The Arduino runs flat out, all the time. That's the way it is designed. The same holds true for any CPU. That the CPU on your PC accomplishes nothing useful a large percentage of the time is only because there is nothing for it to do. Using delay() or sleep() or any do-nothing-for-a-while does not give the processor a rest. It simply gives it something (useless) to do.
Of course.
so why when i do calculations on my pc dose it get a lot hotter?
joshnosh:
Many modern microprocessors support dynamic frequency scaling, which allows the clock frequency and voltage to be lowered to reduce power consumption. The Arduino microcontrollers don’t support anything like that, and I wouldn’t expect to find any microcontroller that does.
Many modern microprocessors support dynamic frequency scaling, which allows the clock frequency and voltage to be lowered to reduce power consumption. The Arduino microcontrollers don't support anything like that, and I wouldn't expect to find any microcontroller that does.
[/quote]
they do indeed. my pc is overclocked though. all the scalling has been disable for reliablity. it still gets much hotter when its working on something...
