My first design.
Hello!
I have made my first non-tutorial based schematic today, and just wanted to share it with you guys.
Sorry for the huge images.
  • Materials Used:
  • Potentiometer
  • Arduino Uno Rev 3
  • Temperature Sensor
  • LCD screen
Schematics:
Sorry for the dotted lines, first time use of Fritzing.
And here is the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int temperaturePin = 0;
  lcd.begin(16, 2);
  lcd.print("Temperature:");
  float voltage, degreesC, degreesF;
  voltage = getVoltage(temperaturePin);
  degreesC = (voltage - 0.5) * 100.0;
  degreesF = degreesC * (9.0/5.0) + 32.0;
  lcd.setCursor(0, 1);
  lcd.print(degreesF);
float getVoltage(int pin)
  return (analogRead(pin) * 0.004882814);
Thanks for checking this out! I know it sucks, first time.
This is the code for the same thing, but with a RGB LED to alert me when the temperature is either higher, lower, or at the same level with a number I have predefined.
int r = 9;
//I have g at 13 because I just want to make sure that
//the curcuits are wired correctly.
int g = 13;
int b = 10;
  pinMode(r, OUTPUT);
  pinMode(g, OUTPUT);
  pinMode(b, OUTPUT);
  lcd.begin(16, 2);
  if(degreesF > setDegreesF - 0.5)// - 0.5 is just roughing it out
   alertR();
  else if(degreesF < setDegreesF - 0.5)
   alertB();
   alertG();
  lcd.setCursor(0, 0);
  lcd.write(degreesF + "F");
void alertR()
  digitalWrite(r, HIGH);
  delay(50);
  digitalWrite(r, LOW);
  delay(50);
void alertG()
  digitalWrite(g, HIGH);
  delay(50);
  digitalWrite(g, LOW);
  delay(50);
void alertB()
  digitalWrite(b, HIGH);
  delay(50);
  digitalWrite(b, LOW);
  delay(50);
Just a couple of things:
1) When posting code use the code (#) icon, not the quote one (the one next to it!).
2) In Setup configure the ledpin pinmode to OUTPUT.
pinMode(ledPin, OUTPUT);
and see if that makes a difference?
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the # button above the posting area.
dannable: Just a couple of things:
Thanks! That fixed the issue!
