this is my first post, so bear with me . I’m an architecture student and
for some time now, I’m planning a wrist watch that I initially sent into a
competition.
I would like to create this watch and develop it further by using the arduino
hardware.
I have ordered the arduino diecimilia kit and I’m just about to start learning elecronics.
I have had some contact with electronics (e.g. building a diy projector), but apart
from that, I’m quite a newb…
So here I have some questions:
clock in general: how precise is the arduino board? do I need an extra quartz? And how would
I use it?
how big is the arduino mini? I’ve read about width and lenght (3x1 cm), but I’ve seen nothing
about the height of the board…
LEDs: I’ll need to order a number of LEDs. What will I have to look at while ordering them?
Do they need to be 5V? Or could I also order 3V LEDs? And where can I find information which
LEDs need what kind or resistor?
and finally: do you know of a super easy explanation of shift registers? I’ve read the tutorial
on this page, but I frankly don’t quite get it. I’ll certainly work it out for myself, but it would
be nice if there was an easy explanation of the concept behind it, somewhere…
sorry, I know, these are quite a lot of questions, I’m thanking
you in advance for any help you can give me!
I use it?
The Dieci has a quartz crystal on it. It should be accurate within about 5 seconds a day. That’s comparable to a commercial quartz watch.
The mini is in the form factor of a standard dip package. Including pins it’s maybe 7mm thick (that’s my estimate).
The LED question is a lot more complicated than that because what people don’t usually recognize is that they’re current devices, not voltage. Basically though, if you want 20mA, the resistor should be ([supply voltage] - [led voltage]) / 0.02. Or 50*(supply voltage - led voltage).
Supper easy explaination of shift registers would be “serial in, parallel out” or “parallel in, serial out” depending on the model.
I use it?
So, if I want to use a bright let that uses 3v/20mA, I should use a 100ohm resistor instead of a 220ohms resistor to have a better light?
thanks
