My first sketch. Hello world and Hello Arduino forums
This is my first go with the Arduino and my first post here on the forum! I have quite a bit to learn about electronics. The nice thing is that the Arduino feels like legos for electronics. I find that it is very easy and inviting to learn as well as fun and rewarding.
I ordered a starter kit and was able to assemble a small binary counter given the items I had. I'd like to turn this into a binary clock, perhaps with an alarm.
Presently it counts to 31 as I only have 5 LEDS and buzzes when it hits 31. You can control the speed with the potentiometer.
Sketch avail on my github page. Sketch
Video
Criticism are welcome! I am here to learn. :)
Your sketch here:
// Array of LED PINS. Makes it easy for our binary counter to decide which LEDS to blink.
int PINS[] = {13, 12, 11, 10, 9};
int delayms = 0;
// the setup routine runs once when you press reset:
  // initialize digital pins as outputs.
  for(int led = 8; led < 14; led++){
    pinMode(led, OUTPUT);
//Blinks LEDS in binary
void blink_binary_number(int number, boolean vol=HIGH){
  for(int led = 0; led < number; led++){
    if (bitRead(number, led) == 1){
      digitalWrite(PINS[led], vol); //Here we use our PINS array to decide which LED to blink. Since I wanted 13 to be bit 0, 12 bit 1, etc...
// the loop routine runs over and over again forever:
 for(int x = 0; x < 32; x++){
   delayms = analogRead(0) * 10;
   if (x == 31){
     analogWrite(8, 254);
   blink_binary_number(x);
   delay(delayms);
   if (x == 31){
     analogWrite(8, 0);
   blink_binary_number(x, LOW);
   delay(delayms);
Your array “PINS” seems to have 5 elements, but you are accessing elements 0 to 31, if I am not mistaken.
Ahh yes. I see what you mean. It didn't immediately pop out to me but inside of my blink_binary_number I am iterating over elements that I never initiated.
Is there a sizeof, length, or size method I can use against an array? For example…
for(int led = 0; led < PINS.length + 1; led++){
digitalWrite(PINS[led], vol); //Here we use our PINS array to decide which LED to blink. Since I wanted 13 to be bit 0, 12 bit 1, etc…
This would allow me to change the size of my pins array without re-writing this method.
Ahh sorry for the noise. I found a good answer here.
Fixed!
int const PINS[] = {13, 12, 11, 10, 9};
int const PINS_SIZE = (sizeof(PINS)/sizeof(int));
int delayms = 0;
  //Serial.begin(9600);
  for(int led = 0; led < PINS_SIZE; led++){
   if (x == 31){
   delay(delayms);
   if (x == 31){
     analogWrite(8, 0);
   delay(delayms);
A generic "size of array" define is this:
// number of items in an array
#define NUMITEMS(arg) ((unsigned int) (sizeof (arg) / sizeof (arg [0])))
Then you have:
int const PINS_SIZE = NUMITEMS (PINS);
Yes. Putting it in a method makes a lot more sense. Thanks Nick!
