My function it does not work
Hi
look here my code and i can’t get the value for Prval = 100 on the glcd
please help
#include <glcd_Config.h>
#include <glcd.h>
#include “fonts/allFonts.h”
gText textArea;
String stringUNO,stringDOS;
int PosX;
int PosY;
int PrMax ;
int PrMin;
int PrVal;
int analogPin1 = A1;
int Fr=300;
GLCD.Init();
GLCD.SetDisplayMode(NON_INVERTED);
GLCD.ClearScreen();
GLCD.SelectFont(System5x7, BLACK); // font for the default text area
GLCD.DefineArea(90,8,110,8);
stringUNO = String(“PrVal.”);
stringDOS = String (“mb”);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
PosX=90;
PosY=0;
GLCD.GotoXY(PosX,PosY);
GLCD.print(stringUNO);
digitalWrite(12, HIGH);
PosX=90;
PosY=8;
GLCD.EraseTextLine();
int Promedio ();// this function it does work
GLCD.print (PrVal);//
Serial.print (PrVal);//For debug only
Serial.print (Fr);//For debug only
delay(Fr);
PosX=115;
PosY=8;
GLCD.print(stringDOS);
digitalWrite(12, LOW);
delay(Fr);
int Promedio (){
PrVal=100;
return PrVal;
You need to declare your function earlier in you code. Try moving it before the loop() function.
elandd2011: My function it does not work
// declare it here, or move the function itself here
int Promedio();
  PosX=90;
  PosY=8;
   // call it this way
   PrVal = Promedio();
  delay(Fr);
  PosX=115;
  PosY=8;
  delay(Fr);
whoa hold on, I thought Arduino generated function prototypes for you... https://github.com/arduino/Arduino/blob/master/app/src/processing/app/preproc/PdePreprocessor.java
frank26080115: whoa hold on, I thought Arduino generated function prototypes for you... https://github.com/arduino/Arduino/blob/master/app/src/processing/app/preproc/PdePreprocessor.java
This isn't valid syntax:
Either assign something or remove the int. eg.
int x = Promedio ();
or
Promedio ();
It is perfectly valid syntax, otherwise, it wouldn't have compiled! It is simply a function prototype, not a call to the function.
Looks like you are right. ;)
Oh well, it "doesn't work" in the sense that it didn't call the function, like you said.
When people post that things "don't work" you often have to guess whether they mean "doesn't compile" or "doesn't do what I expect".
Agreed - my least favourite phrase is "it doesn't work".
Thx guys and you are right the real problem is it doesn`t do what i expect, but it compile well thx guys
