I am using arduino uno , simple button and gpio expander aw9523B.
I need more pins for another project but first i wanted to test if it works as it should .
i2c scanner found the address, so i wrote some simple code to turn on the build in led on arduino and when the button is released the led turns off.
However for some reason sometimes when the led is turn off it will blink one or twice without pressing the button and after every release there is a delay usually 1 or 2 second before the led turns off.
Here is my code
#include <Wire.h>
#define AW9523B_ADDRESS 0x58 // I2C address of the AW9523B
#define REG_INPUT_PORT0 0x00 // Register to read input state
#define REG_CONFIG_PORT0 0x04 // Register to configure pins as input/output
#define REG_PULLUP_PORT0 0x0C // Register to enable pull-up resistors
Wire.begin();
Serial.println("AW9523B Button with Debouncing and Arduino LED");
pinMode(LED_BUILTIN, OUTPUT); // Configure Arduino built-in LED as output
// Configure P0_0 as input and enable pull-up resistor
writeRegister(REG_CONFIG_PORT0, 0b11111111); // Set all pins to input
writeRegister(REG_PULLUP_PORT0, 0b00000001); // Enable pull-up on P0_0
static byte lastButtonState = 1; // Button starts in released state
static unsigned long lastDebounceTime = 0;
const unsigned long debounceDelay = 50; // Debounce delay in milliseconds
// Read button state from P0_0
byte currentButtonState = readRegister(REG_INPUT_PORT0) & 0x01;
// Check if the button state changed
if (currentButtonState != lastButtonState) {
lastDebounceTime = millis(); // Reset debounce timer on state change
// If the button state has been stable for longer than debounceDelay
if ((millis() - lastDebounceTime) > debounceDelay) {
if (currentButtonState == 0) { // Button pressed (active LOW)
digitalWrite(LED_BUILTIN, HIGH); // Turn LED ON
} else { // Button released
digitalWrite(LED_BUILTIN, LOW); // Turn LED OFF
lastButtonState = currentButtonState; // Update last button state
void writeRegister(byte reg, byte value) {
Wire.beginTransmission(AW9523B_ADDRESS);
Wire.write(reg);
Wire.write(value);
Wire.endTransmission();
byte readRegister(byte reg) {
Wire.write(reg);
Wire.requestFrom(AW9523B_ADDRESS, 1);
return Wire.read();
Thank you for this code , it solved the delay after releasing button problem , but it did not solve a problem with random blinking of led when the button is pressed.
yes of course . here are the numbers:
at 50 the button detect all clicks , there are no delays , random blinking happens,
at 100 the button detect all clicks , there are some short delays, random blinking happens,
at 200 the button ignores short clicks (which is bad cause i need fast reaction time for my project), there are some long delays,random blinking happens,
I really cant see a pattern in this random blinking they are mostly short and mosty after longer press however there are exceptions.
