I bought a ublox neo6mv2 (neo-6m-0-001) gps module and it is the first time I use it. I will be using this module in a project with Arduino, but I noticed that my gps module is not sending data (it was where it saw the sky). The led on it is flashing. So it must be getting enough data from satellites. I removed the Gps from Arduino and connected it to the computer via Usb-TTL (FT232RL). When he turned on the GPS he wrote to the Serial Monitor:
(--- Enter port index or full name: COM6
--- Miniterm on COM6 9600,8,N,1 --- )
$GPTXT,01,01,02,u-blox ag - www.u-blox.com*50
$GPTXT,01,01,02,HW UBX-G60xx 00040007 FF7FFFFFp*53
$GPTXT,01,01,02,ROM CORE 7.03 (45969) Mar
17 2011 16:18:34*59
$GPTXT,01,01,02,ANTSUPERV=AC SD PDoS SR*20$GPTXT,01,01,02,ANTSTATUS=DONTKNOW*33
$GPRMC,124637.63,V,,,,,,,260521,,,N*7F
$GPVTG,,,,,,,,,N*30
$GPGGA,124637.63,,,,,0,00,99.99,,,,,,*66
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
$GPGSV,4,1,13,05,01,036,,10,40,184,,13,02,052,,15,15,080,*78
$GPGSV,4,2,13,16,49,298,,18,62,030,,20,18,044,,23,65,141,*77
$GPGSV,4,3,13,25,00,157,,26,59,250,,27,22,305,,29,30,100,*7D
$GPGSV,4,4,13,31,03,220,*4A
$GPGLL,,,,,124637.63,V,N*4A
$GPRMC,124638.00,V,,,,,,,260521,,,N*75
$GPVTG,,,,,,,,,N*30
$GPGGA,124638.00,,,,,0,00,99.99,,,,,,*0C
$GPASV,4,1,1␓, 5,01,032,,10($0X184,X13,02,0␅2, 15(15,080,30*7␀
␄␇@GSF$4,2 03,16␌␄␀␂␀␂␂D
␀�"� ␄� ␀␀␀␀@␀␀␀�␃%␐␒␀␀␂␌C␀␀�*␐�␀`␀␁�� ␀␀␀␀␄␀␁␀�␀␀␂␀␀␀X ␀␀␀␀�␎
␂ GPDPT,4X␀�ňb��`␀4�I␁␓␒ MP@��GPDXP�Ē"d$␂2␄␀b��r␀��b�@�
␅␅␁␕ Q␁␐␐�$�PPPTTP��S=��␀P���j�D`
␀Uj␔R ML��␆5 X���b``b�$R�� ␀␒�J�␓�␀␔␀␕�␀�����␐␒␐$)�LL␀�␀@P␄�␀���␀���␐␀,,0(␀ ,0, dP��b``␀T@�H��␐���P␀␀�␐,10X@ؠ��b ��I�␐@�␂$␀��, .0pXȸ��`␀�@␒P� ␀QTQ�� 4X`���`��@␄␀�␀␚$␂␀b�␂␂␄�b���`@��B␄$�␀I��␀!1 ␁5(080@dਸ␀
␀␎␀�␄␙�␂␂␄␄ ␁ �␓␄�␎␜␘,␒0␌␄␆␀␀0␁␀ ␀ ␀0P␂ఀ��@␀␀�␐␀␀␀H�� ␀`␚␀@�␀␀�@��@�␀ ␀P␀
�␀P␀ X`���@�␀�␀B���bR�
դ␀ ␀�␄��␁␂␀␁!␁␀␐�␀␀A␀�␀ @P␀␀␀␀␀␀�␀)␁␁�Ӧ' ␀␒␀␕� ␂���I�␓␂��␆B␁␆␀�␀␀␐ ␀␀@␀
@@␀␀␃␄␀␆␂�Œ����b␄�``b`b�b��b�r��bBB␂bBR
␒�␀␀@␀␀P␀␂␀␀␀ ␀␀`␀␆␀␀␀␀␀␀␂
␄␀␀␀␀�␀␀␀␁␀␀␀`␀␃�␀␀␀␀␀`��@�(␀␀␄␀␀␀␂�␀b␀␁␂␁␀␁␄␁␀␀H␀␀␀�␀␀␂␀␀␁p("0,␁8(044,,23,65␌14␁,*75
$G@FSV,4(3X13,25␌0 ,157(,24 58,00`XA� ��b
�b␚�*b��B␂�b��␂␂�␀`��P��`�@��␀␕% JM��␑,0bX@� ��␀bB"
␒� ␁␃␂&�␆␇␁␓␓�␕�S@␁�������␀
(These data are not significant and are increasingly distorted)
Then it stopped and did not send any other data. When I turn the power off and on, I never got data again.
When I measured the voltage of the battery on the module with a multimeter, I saw that it was 3V. Should it be 3.3V?
Why might it not be sending data? And why might the data I receive have been increasingly corrupted?
Thanks
