when I checked my GPS sensor with Arduino Mega independently, It works properly.
but, when i add GPS sensor codes into my overall codes, it doesn't work properly and keep says GPS value(lat,long) is 0.0000. I want to fix this problem. how do I fix this? GPS sensor got its power and I can see the red light on GPS Sensor. It is not because cold start. please help me.
here's my code.
#include <SoftwareSerial.h>
SoftwareSerial esp8266(2, 3); //esp8266 시리얼 통신 설정
#define esp8266 Serial3 //esp8266선을 RX,TX3으로 수정
#define BAUDRATE 9600
#include <TinyGPS.h>
#include <Wire.h> //BH1750 조도센서 라이브러리 포함
#include <BH1750FVI.h>
#include <DHT.h> //DHT22 라이브러리 포함
// 핀 설정 및 센서 기본 변수 설정
#define DEBUG true //esp 설정
#define DHTPIN A0 //DHT22 온습도 센서 핀 설정
#define DHTTYPE DHT22
#define MG_PIN A1 //MG811 CO2센서 핀 설정
#define VltS A2
#define BOOL_PIN 2
#define DC_GAIN 8.5
#define READ_SAMPLE_INTERVAL 5
#define READ_SAMPLE_TIMES 5
#define ZERO_POINT_VOLTAGE 0.220
#define REACTION_VOLTAGE 0.030
#define RCPin1 3
#define RCPin2 4
//라이브러리별 설정
DHT dht(DHTPIN, DHTTYPE);
BH1750FVI::eDeviceMode_t DEVICEMODE = BH1750FVI::k_DevModeContHighRes;
BH1750FVI LightSensor(DEVICEMODE);
SoftwareSerial uart_gps(5, 4);
#define uart_gps Serial2
TinyGPS gps;
//전역변수 설정
float hum;
float temp;
float CO2Curve[3] = {2.602, ZERO_POINT_VOLTAGE, (REACTION_VOLTAGE / (2.602 - 3))};
float volts;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000.0;
float R2 = 7500.0;
float Latitude, Longitude;
int Vval = 0;
int RCValue1;
int RCValue2;
int Angle;
int Spd_rpm;
int Spd_rps;
//String형태로 입출력 변수 설정
String AP = "bime0304_2.5G"; //Wifi설정
String PASS = "bime0304";
String WApiKey = "CU8634SH66Q1MLO9"; //ThingSpeak 내 Write API
String RApiKey = "XMP6OYHXR8RYX55A"; //ThingSpeak 내 Read API
String HOST = "api.thingspeak.com";
String PORT = "80";
String fieldTemp = "field1"; //Air Temperature 필드1 설정(최대 8)
String fieldHum = "field2"; //Air humidity 필드2 설정
String fieldLight = "field3"; //Light Intensity 필드3 설정
String fieldCO2 = "field4"; //CO2 센서 필드 4 설정
String fieldlat = "field5"; //GPS 위도
String fieldlon = "field6"; //GPS 경도
String fieldangle = "field7";
String fieldspeed = "field8";
int countTrueCommand; //ESP8266 커맨드 카운트 함수
int countTimeCommand;
boolean found = false;
int percentage; //CO2센서 전역변수 설정
//CO2 계산 함수
int MGGetPercentage(float volts, float * pcurve) //MGGetPercentage 변수
if ((volts / DC_GAIN ) >= ZERO_POINT_VOLTAGE) {
return -1;
return pow(10, ((volts / DC_GAIN) - pcurve[1]) / pcurve[2] + pcurve[0]);
float MGRead(int mg_pin) //MGRead변수
int i;
float v = 0;
for (i = 0; i < READ_SAMPLE_TIMES; i++) {
v += analogRead(mg_pin);
delay(READ_SAMPLE_INTERVAL);
v = (v / READ_SAMPLE_TIMES) * 5 / 1024 ;
return v;
void getgps(TinyGPS&gps) {
gps.f_get_position(&Latitude, &Longitude);
int year;
byte month, day, hour, minute, second, hundredths;
gps.crack_datetime(&year, &month, &day, &hour, &second, &hundredths);
unsigned long chars;
unsigned short sentences, failed_checksum;
gps.stats(&chars, &sentences, &failed_checksum);
unsigned int i = 0;
// Open Serial1 communications and wait for port to open:
// 시리얼 1 통신 시작 및 열릴때까지 대기
esp8266.begin(BAUDRATE); //ESP8266 보드레이트 설정
esp8266.setTimeout(5000);
uart_gps.begin(9600);
dht.begin(); //온습도 시작
LightSensor.begin(); //조도 센서 시작
Serial.begin(9600); //시리얼 통신 시작
pinMode(RCPin1, INPUT);
pinMode(RCPin2, INPUT);
pinMode(BOOL_PIN, INPUT);
pinMode(VltS, INPUT);
digitalWrite(BOOL_PIN, HIGH);
Serial.println("Thingspeak with ESP-01");
//ESPWiFi 셋팅
sendCommand("AT", 5, "OK");
sendCommand("AT+CWMODE=1", 5, "OK");
sendCommand("AT+CWJAP=\"" + AP + "\",\"" + PASS + "\"", 20, "OK");
//IP획득 및 표시
sendCommand("AT+CIFSR", 2, "OK");
delay(2000);
//반복 조건
hum = dht.readHumidity(); //습도 읽는 함수
temp = dht.readTemperature(); //온도 읽는 함수
uint16_t lux = LightSensor.GetLightIntensity(); //조도 읽는 함수
Vval = analogRead(VltS);
vout = (Vval * 5.0) / 1024.0;
vin = vout / (R2 / (R1 + R2)); //전압 센서
volts = MGRead(MG_PIN); //CO2내 전압
percentage = MGGetPercentage(volts, CO2Curve);
RCValue1 = pulseIn(RCPin1, HIGH);
RCValue2 = pulseIn(RCPin2, HIGH);
Angle = map(RCValue2, 1000, 1900, -45, 45);
Spd_rpm = map(RCValue1, 1000, 1900, -15080, 15080);
Spd_rps = Spd_rpm / 60;
while (uart_gps.available()) {
int c = uart_gps.read();
if (gps.encode(c)) {
getgps(gps);
//시리얼 표시
Serial.print(" lat: ");
Serial.print(Latitude, 5); //GPS 위도
Serial.print(" lon: ");
Serial.print(Longitude, 5); //GPS 경도
Serial.print(" alt: ");
Serial.print(gps.f_altitude());//GPS 고도
Serial.print(" Spd: ");
Serial.print(Spd_rpm);
Serial.print(" Angle: ");
Serial.print(Angle);
Serial.print("Humidity: ");
Serial.print(hum, 1); //습도 소수점 첫째 표시
Serial.print(" %, Temp: ");
Serial.print(temp, 1); //온도 소수점 첫째 표시
Serial.print(" Celsius, ");
Serial.print(lux); //조도 표시
Serial.print(" lux, ");
Serial.print(volts); //CO2볼트 표시
Serial.print("V, ");
if (percentage == -1) { //CO2 값 표시
Serial.print( "<400" );
else {
Serial.print(percentage);
Serial.print( "ppm, " );
if (digitalRead(BOOL_PIN)) //CO2 BoolPin 상태 보고
Serial.println( "HIGH" );
Serial.println( "LOW" );
//Thing Speak 서버에 업로드
//통합 시도
sendCommand("AT+CIPMUX=1", 5, "OK");
String getData = "GET /update?api_key=" + WApiKey + "&" + fieldTemp + "=" + String(temp) + "&" + fieldHum + "=" + String(hum) + "&" + fieldLight + "=" + String(lux) + "&" + fieldCO2 + "=" + String(percentage) + "&" + fieldlat + "=" + String(Latitude) + "&" + fieldlon + "=" + String(Longitude) + "&" + fieldangle + "=" + String(Angle) + "&" + fieldspeed + "=" + String(Spd_rpm);
sendCommand("AT+CIPSTART=0,\"TCP\",\"" + HOST + "\"," + PORT, 15, "OK");
sendCommand("AT+CIPSEND=0," + String(getData.length() + 4), 4, ">");
esp8266.println(getData); countTrueCommand++;
sendCommand("AT+CIPCLOSE=0", 5, "OK");
// ESP 커맨드 입력 및 전송상태 수신
void sendCommand(String command, int maxTime, char readReplay[]) {
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while (countTimeCommand < (maxTime * 1))
esp8266.println(command);//at+cipsend
if (esp8266.find(readReplay)) //ok
found = true;
countTimeCommand++;
if (found == true)
Serial.println("OYI");
countTrueCommand++;
countTimeCommand = 0;
if (found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
+this is my serial monitor
